Hi Guys!
Is the diesel clutch cover plate same like the 1.4 clutch? Also the axle between the clutch and the propshaft?
1.4 clutch vs diesel clutch
Re: 1.4 clutch vs diesel clutch
Volvo part numbers:
B14 (MT) Clutch:
3203770 Driven plate / Friction disc
3294532 Clutch cover
3209530 Release bearing
3209994 Clutch to prop connecting shaft
D16 Clutch:
3560028 Driven plate / Friction disc
3299530 Release bearing
3560559 Clutch to prop connecting shaft
From the above, the diesel friction disc and connecting shaft is different (diameter +10mm, spline size different), but the cover and the release bearing are the same.
A Sachs catalogue:
1861 870 142 B14 Driven plate / Friction disc (190mm / 20 spline) (190TPB) (20,1x22,3-20N)
1878 600 829 D16 Driven plate / Friction disc (200mm / 20 spline) (200CPE) (20x23-20N)
3082 098 131 B14/D16 Clutch cover
3151 078 001 B14/D16 Release bearing
B14 (MT) Clutch:
D16 Clutch:
A Sachs catalogue:
