Radius arm to chassis rod
Post by bogbasic »
Hello, I need some advice because I am trying to change the bushes on the above said rod and on removal I found the following:
The strut was replaced with a repaired one by the previous owner's mechanic and they have obviously used a cutting disc to square-off the bolt-heads for ease of removal. Funny cos a flipping 53 year old with backache managed to do the other side non-destructively with only molegrips and spanners, duh. The cuts are about 2 - 3 mm deep from eyeballing them. Could a welder fill in the cuts or is it not necessary? Bit perplexed.
Anyhow, what thinks thou?
360beast
Re: Radius arm to chassis rod
Post by 360beast »
I personally would get them filled in for piece of mind and those cuts will make a weak point so a big pot hole could cause damage.
volvomania
Post by volvomania »
Either replace them or get them welded up.
But leaving them as is is a big nono for me as the cut weaken the entire rod.
Post by bogbasic »
Cool, thanks both.
thododd
Post by thododd »
Ill swap you for a good'un
Post by bogbasic »
Gosh - sorry. I took it to the welder just now. He'll do it for a beer ;-§
Post by classicswede »
and how many years had it functioned like that for?
Post by bogbasic »
I think not many - I can check in the history if you're interested. It was the one you supplied to colin340 in Shropshire a couple of years ago, I think, from memory. The strut itself is great, bar the mechanic's efforts to remove the tie bar ;-0 and I painted your strut in black hammerite - thought it was better than leaving it in primer ;-0
It now has new calipers from the Macster.
Post by bogbasic »
Cool, repaired....
Looks much better now
Post by bogbasic »
Thanks for the rock and Merry Crimbers!
