ole reliables hit self destruct
olie30
Post by olie30 » 27 Dec 2016 11:19 am
Hi all, my 340 has decided to commit suicide by eating its air box bolts, im lookiing for a running 1.4 (B14.4E) engine, pleeeease somebody keep the old girl going!!!! Im based near leam spa. Cheers, oli
Re: ole reliables hit self destruct
Post by bogbasic » 27 Dec 2016 03:49 pm
Very sorry to hear that, good luck.
olie30
Post by olie30 » 27 Dec 2016 05:06 pm
Yeah im guna need it :( all i can find is renault 5 engines and i believe the only one thats a simple swap is the gt5 engine.. which commands a premium :( im thinkin about just goin 1.4 turbo but thatl cost me a mint to part up
Post by bogbasic » 27 Dec 2016 10:10 pm
Dumb question, but can you explain what you mean by eating the air box bolts?
olie30
Post by olie30 » 29 Dec 2016 11:47 am
The three studs that bolt the air box to the carb, theyv been loose and iv had to put other bolts in, they came loose again unbeknown to me and a bolt n washer dropped into the carb, managed to get the bolt but the washers in there somewhere, probably mashed into the bottom of the head. I had the rocker off, push rods n valves look ok on top, no1 spark plug was smashed, waved a magnet about n replaced spark plugs and shes ratteling like hell. Shes my daily driver and im a bit footaad, it seems nobody bothered keeping the 1.4's as i cant fine one anywhere atall :(
benji1985
Post by benji1985 » 29 Dec 2016 01:56 pm
olie30 wrote:The three studs that bolt the air box to the carb, theyv been loose and iv had to put other bolts in, they came loose again unbeknown to me and a bolt n washer dropped into the carb, managed to get the bolt but the washers in there somewhere, probably mashed into the bottom of the head. I had the rocker off, push rods n valves look ok on top, no1 spark plug was smashed, waved a magnet about n replaced spark plugs and shes ratteling like hell. Shes my daily driver and im a bit footaad, it seems nobody bothered keeping the 1.4's as i cant fine one anywhere atall :(
Well I don't see how a stud could have got through the carb in to the engine, but it is a real simple job to take the head off.
Talk to Mac about a refurbished carb and let's see what state the engine is in, take the head off, gaskets are still easy to obtain.
Where do you live? Sure somebody lives near you to help
olie30
Post by olie30 » 29 Dec 2016 04:44 pm
As I say its only a washer thats found its way through, the three studs were in the carb ports and two washers were strewn about and the third washer is nowhere to be seen. The knock she has when running is painful. Il be taking the head off asap but shes stuck outside my place two miles from my workshop.. which is full of e30 and its associated engines iv killed haha. Atm id rather seperate the inlet and swap the engine for simplicity but these b14s seem to be somewhat illusive
benji1985
Post by benji1985 » 29 Dec 2016 05:42 pm
Get that head off, probably just need to fix that.
Parts can be sorced, lets see how bad the damage is
Ben
Post by MCHUDD » 30 Dec 2016 11:30 am
All is not lost. I did this years ago in a 1.4.
Drove around for years with a ratttle lol.
sm4 sm4 sm4 sm4 sm4 sm4 sm4 sm4
olie30
Post by olie30 » 31 Dec 2016 09:47 am
Thankyou guys, il be taking the manifold off in a bit n if i find nothing that way then heads coming off. Lol Mark, i like the way you think mate
benji1985
Post by benji1985 » 31 Dec 2016 01:08 pm
olie30 wrote:Thankyou guys, il be taking the manifold off in a bit n if i find nothing that way then heads coming off. Lol Mark, i like the way you think mate
Let us know how it goes, plus talk to Mac about your carb he's a genius :)
Ben
olie30
Post by olie30 » 02 Jan 2017 12:22 pm
Heads off, carbs okay, theres big chunks outa the head just under the spark plug and a bit of washer welded onto the piston that has been mashing up against the head. Id say new engine i cant be arsed to change just the head when a pistons compromised. I was lookin at a fresh c1j engine.. but the compression ratios 7:9:1, way way lower than n/a setup... now i dont know what the hell to do :(
benji1985
Post by benji1985 » 02 Jan 2017 02:03 pm
olie30 wrote:Heads off, carbs okay, theres big chunks outa the head just under the spark plug and a bit of washer welded onto the piston that has been mashing up against the head. Id say new engine i cant be arsed to change just the head when a pistons compromised. I was lookin at a fresh c1j engine.. but the compression ratios 7:9:1, way way lower than n/a setup... now i dont know what the hell to do :(
Put a request out for a cylinder head and piston, more likely to be able to be found.
Please message Mac as he has lots of bit and is more likely to be able to help
Ben
Minibuzz
Post by Minibuzz » 02 Jan 2017 04:35 pm
You in Warwickshire? Have you thought of upgrading to a 1.7? People tend to sell them after doing engine swaps so might be more about?
Post by classicswede » 02 Jan 2017 08:24 pm
I have a couple of 1.4 engines available
