Window minding mechanism wanted
ereg340
Post by ereg340 »
I need the window winding mechansim for the drivers door off my 340. Its the scissor type thing that goes inside the door thats a swine to get out which I'm after. The window used to come down if you went over a speed ramp and recently I wound it right down in the sun and could'nt get it to go back up properly .
The glass when it is raised does'nt fit snuggly so there' always a draft. Tried down the volvos breakers. ....
''No ones asked for one of them for 5 years mate Ha Ha ha''
Ereg340 :)
Where in the UK are you? Someone should be able to source one no problem. As you say, it is a pain to get out of the door though and it needs to be in the correct position to be removed from the inner door panel
JOHN360
Post by JOHN360 »
I both winding mech. from my 5 dr 340 that I converted to electric still in a draw in the garage. email me at jallam@supanet.com if these are what you're after.
Cheers,
John.
Current : No 300's anymore !
Image Image
Post by 340GLT »
If you need a 3 door mech i have both drivers and passengers side available!!!
Cheers Adam
LankyTim
Post by LankyTim »
ive got one you can have for nothing,
