what next?
ebdl
what next?
Post by ebdl »
Further adventures of the mk.II variomatic.
Right, so I've replaced the carb with a decent one and the problem of hesitation/no revs when applying the accelerator has gone. I still don't think it's running properly and it's running very rich - I can't get it to idle anywhere near two full turns of the mixture screw. Sometimes it'll just run very fast and I can't get it to idle smoothly at all (and yes, the carb bolts are all nice and tight). Very embarrassing not being able to get it in gear with a huge queue behind me at the petrol station because the revs wouldn't drop down low enough to get it into Drive. Also when I lift off the accelerator, the engine braking is accompanied by a load of crackling noises from the engine.
What should I be looking at next?
Thanks,
Post by foggyjames »
Coming to the Donny meet? We could take a look ;)
Sounds like it's running pig-rich. Is it lumpy at all? Those engines develop a clear chugging sound when running rich. When the mixture is set right, they're beautifully smooth. Nessy's is a bit rich at the moment, so that it just starts to shake if left idling for more than about 20 seconds.
ebdl
Post by ebdl »
It's definitely running rich... mostly because I can't get it to run any other way. Someone mentioned air/vacuum leaks as a possible problem in the past. Does this sound likely? Where would I look for them?
Not sure I can make Donington - the medics' rugby team are taking on a touring side from America, possibly too much of a comic opportunity to miss. (And I managed just over 100 miles off the last tank, which would make for a very expensive 250-odd miles up there.)
Ok, sounds like you have a monster vacuum leak, and you're having to run it majorly rich to compensate, but that results in a high idle.
Take it all apart (yes, all of it :)), replace anything that looks leaky, tighten it all up, and you should be AOK. Also verify that the breather hose is hooked up, and that the restrictor is in place - you should be able to feel it as a hard 'nobble' in the hose. Gemma managed it, and she's a girl sm56 sm56 sm56
Countdown to hell breaking loose....
5....
4....
3....
2....
V6 Man
Post by V6 Man »
Go on Gem, I'll hold him down while you kick him.......
petavius
Post by petavius »
Do I laugh or cry?! I guess its a kind of back-handed compliment! :D
340GL 1984 B406 AJO - scrapped (sob)
340GLE 1987 E880 UUX
ebdl
Post by ebdl »
Hmm... sounds like a job for the easter holiday in 5 weeks' time.
Thanks for info. When you say take it all apart, I presume you're just talking about the vacuum system and not the whole car :shock: :lol:
I learnt what little mechanical knowledge I have on 2CVs, so you'll have to excuse me if my understanding of these things is a little basic.
I think he means teh entire carb! Thats what I did on Fake, and needed to do on Kar, make sure yuo do it on newspaper, and a digi cam helps when you after you forget how it goes back together ;)
Yeah, take the carb off and take it to bits. If you have the time / inclination, do the manifolds as well. Check the manifold to downpipe nuts for tightness while you're there...if they're loose, it runs like a bag of spanners.
