740 > 340 axle swap -possible??
Essex1
Post by Essex1 »
Hi all
Does anyone know if its possible to chuck a 740 rear axle on the back of a 340 (removing the 340 one first, obviously :roll: ) ?? If so how, if not what are the probs? Just curious really...
Post by 340GLT »
TBH mate you will have a major job on your hands here. The 300 has a transaxle so no Gearbox up front whereas the 740 is a traditional box up front prop rear axle layout!!!
Essex1
Post by Essex1 »
Fair enough, but assuming you were prepared to cut a nice new tunnel and hypothetically speaking...would it fit dimensions wise??
990
Post by 990 »
I am pretty sure the 700 series axle is a little too wide for a 300 :shock:
Volvo 360 -- Small Car - BIG Ideas
E990 UBA Volvo 360GL - Vanised
D133 OBU Volvo 340GL - Died
F330 FWB Volvo 360GLT - She Runs :)
GJ53 GPF Volvo S60 - Daily
Fuse
Post by Fuse »
Essex1
Post by Essex1 »
:shock: :shock: :shock: I am in awe and not worthy of such engineering genius!! Whats the difference between the 240 and 740 axles - i thought they were similar?? I know you can get the 740 with an automatic locking diff, which I suspect might be useful for sidewaysedness...
Fuse
Post by Fuse »
Inside parts of 200-,700-, and I guess also 900-series diffs are interchangeable. So differences are external. :P With stiff axels that is, about multilinks I don't know.
