Shiny Nessy
jeez - how is that rad not leaking like a sieve? you're aware the pipe is just stuck on with glue, right?
Swapsea-'89 360GLT-swapped!
- petefarrell360
"Mechanically speaking, there's not too much to sort out now, but James, you do need to change that hose ASAP, before it bursts on you, I'd recommend changing before driving it anywhere as its pretty swollen and soft." Along with all fluids need changing etc!
Ahhh, I think you're thinking about a different hose. This is the hose going to the carb baseplate, considering it was p*ss*ng out water as soon as the car was switched on and was swollen to double its size because of the engine oil that had leaked all over it.......anyway, it got changed before it blew up
- foggyjames
One of the copper hose attachment has definitely been stuck on using some sort of chemical metal / JB Weld product, but it seems to hold AOK.
I can't find any glue at the moment, but that doesn't mean there wasn't some at some point in the past!
