 And the bonnet, damaged or not?
 And the bonnet, damaged or not?CRASH (My Redline aint very well )
Any bits you still need Redline? I still have my old grill, and can get my coloured bumpers swapped over a bit quicker if you need a front black one
German and Swedish had my 1.4 rad in stock, about £40 (though that was about 2 years ago)
the radiator is almost 100% sure just off its mountings, try giving it a shove back in the right direction.
Swapsea-'89 360GLT-swapped!
Hi  Redline
If the rad is shot and you have no joy with secondhand parts, Euro car parts have them in at £72+VAT.
There is a branch just off the V4 Watling St. a couple of miles from you
www.eurocarparts.com
Will
Will
if its not leaking its not a problem
if you're worried about it then wait till one comes up on ebay
checked today the centre core of the rad was pushed back onto the fan by the bumper iron the mountings are ok the rad is more mis shaped than damaged so I should be able to gently push the core forward to clear the fan and it will be ok I have driven the car since and there are deffinately no leaks, I would also like to take this opportunity to again thank Pete Farrell who true to his his word turned up at my house with all the bits last night thanks mate
				petefarrell360
have now managed to push the  radiator core more or less back into shape and just to be on the safe side have put a couple of spacer washers between the fan bracket and front panel. ran her for a while until fan cut in and it all works fine. because of the damage to the front panel where the bumper bracket bolt on , I am having a bit of trouble lining the brackets    up with the bumper bar . But with a bit of gentle persuaision   and a large hammer
 and a large hammer  and some colourful language
 and some colourful language  I a m sure I will get there in the end if it just stops raining for long enough
 I a m sure I will get there in the end if it just stops raining for long enough  so i'm now a happy chap again
									 and a large hammer
Oh I forgot to say , if anyone has a textured front bumper in black at the right price i might be interested , the one pete was kind enough to bring me is a smooth one from a 360glt and is great for now coz it means the car is usable again but i want to get it back to as near as original as poss (fussy bugger aint I ) I think chris_c said he may have one
