common rust problems
1.4 Volvo 34o
on my 340 the out side rear wheel archs have rust holes. i would like to know where the most common rust areas are and, what i could do about the rust on the wheel archs.
1988 1.4 Volvo 340 5dr
common rust areas
wheel arches
sills
rear jacking point - inner sill
rear chassis on ends of cross bar
front wings
front pannel
door tops by the glass
5 door models the seam from wheel arch to sill inside of door
and probably quite a few other places.
Reapair pannels are available for the arches but if still in early stages I will fabricate and weld in repair patches.
wheel arches
sills
front wings
front pannel
Missed a very important one.
The front spring cup on teh stut. Mud gets trapped in there causing them to rot out. Give them a good check over.
1.4 Volvo 34o
Dont forget the right rear inner fender, behind the metal fuel breather pipe. That bit is rotten on a lot of cars too.. for the rest the abovementioned things are all correct.. especially the sills around the jacking points are very weak. also look for flattened chassis rails caused by experimenting with different jacking points. Did anyone mention the front panel behind the headlights, specifically around the towing hooks.. also a very nasty spot.
Truth be told, 300's are pretty nasty in the rust department,, but then what do you expect from an 80's econobox type car..
- petefarrell360
A pillars and door pillars and under the windscreen!
Bottom front corners of the front doors, about 20 mm in from each edge.
A bad example can rust anywhere! Prevention is the best method, and knowing roughly where to look is always useful!
Strip car so that it is only a chassis, then sandblast it completely, fix problem areas, sandblast again, dip whole car to cold zink bath (was it only 300C?
), take it out and repaint with good layers of paint, repeat procedure for hood, bootlid and doors.
Now you can enjoy rather care free motoring for next 5 years or so, if you do careful rust proofing every year, then it might last next 20 years quite easily if there was no rust hiding inside structures, if so then you need to cut it bit more
It should not be too expensive either, sure costs a lot but not anything insane, biggest problem is amount of work and space needed.
A lot ff rust is caused by the bad drainage of the front wings. Water gets through the wing gutters and rots the bulkhead and near the macpherson struts. Best to remove the wings to treat and put lots of sealer on when replacing wing.
Good luck for a Forth Bridge job, Steve
1989 340DL,1397
1979 CapriGL ,1593
1979 CapriGL ,1593
