When you get used to it you can fit the cable to back of the spedo by reaching around from under the dash.
Pushing the cable through the rubber sleeve in the hub is teh only issue I've had and ican be sorted with a bit of lube.
The grease cap is best removed and then refitted once you've pushed the cable through.
Speedo ARRRR!!!
