0-60mph: 23 seconds (1.4 litre)
340GLT wrote:If my 140mph speedo is accurate then my car does 85 in 3rd on the limiter and 112in 4th on limiter
A GLT will do that stock... :wink: Although 500rpm less with the taller diff
germ
Post by germ »
My 1.7 will do it around 9-11 secs to 60 and pulls quick in 3rd.. i think it will do 100mph in 3rd? what i do know is that by 80 it slows accel alot!
will
Volvo 340 Image 1988
Post by jtbo »
germ wrote:My 1.7 will do it around 9-11 secs to 60 and pulls quick in 3rd.. i think it will do 100mph in 3rd? what i do know is that by 80 it slows accel alot!
will
Hmm, 360GL with 3.36 diff will do 93kph with 2nd and bit above 150 with 3rd, I don't think 100mph is possible with any combination unless revving far beyond safe range?
Anyway 3rd is ridiculously tall gear in these boxes, old M46 was so much better, I have one in my daily driver :) Too bad those boxes never made to 300 :(
jtbo wrote:Anyway 3rd is ridiculously tall gear in these boxes, old M46 was so much better, I have one in my daily driver :) Too bad those boxes never made to 300 :(
+1... My 360 feels quicker from 65-80, than it does from 50-70 in third!
Pappa
Post by Pappa »
jtbo wrote: Anyway 3rd is ridiculously tall gear in these boxes, old M46 was so much better, I have one in my daily driver :) Too bad those boxes never made to 300 :(
I agree, but as a side effect you hardly use fuel when going 60, 70 (in third) and 80 (in fourth) km/h
dalahare
Post by dalahare »
My 360glt took pretty much bang on 13 seconds to 100kph tonight, could have shaved a few tenths off by flat changing, but the old girl gets abused enough.
That's a true 100 kph too, reads 112 on my speedo.
MJ
Post by MJ »
Never head of flat changing before, but it seems to involve keeping the throttle wide open during a quick gear change. Doesn't sound too great for the car :P.
I just read one site where someone mentioned not using the clutch while changing gear. I've done that a few times, but you have to exactly match the revs or you get horrid grinding noises :oops: Very occasionally I'll slip to neutral without the clutch when down changing to avoid the first part of double clutching, but you have to ease off the throttle a bit.
hatch360
Post by hatch360 »
dalahare wrote:My 360glt took pretty much bang on 13 seconds to 100kph tonight, could have shaved a few tenths off by flat changing, but the old girl gets abused enough.
Thats te same time i got but that was when it was not mechanically sound the time should be better than 13. How did you measure it?
dalahare
Post by dalahare »
Stopwatch from the standing start till the speedo swept past 110kph. did it a few times, and it was normally in the high twelves. it did have a full tank of fuel, a few few spares in the car and my fat arse weighing it down. :lol:
Pappa
Post by Pappa »
Well I changed the breather hoses and the time is now down to about 18 seconds 0-100kph. Still too much though, and it's not really 100 kph, just what's indicated on the speedo.
pettaw
Post by pettaw »
If you've got bent steering or suspension then its not going to run straight so you won't get a true time anyway. I would suggest a full mechanical going over, first and then you can try 0-100 times ;)
