Relay E14
- RandomHero
Relay E14
Hello,
I have a questing. I am currently trying to connect fog-lights in my 1987 360 GL. I don't realy know which wires are already there. To make the connection complete i need to know where i can find relay E14. I hope it all falls in one piece when i know where it is. It's somewhere in the centerconsole i guess, that's all i know.
Who can help me?
Gr Thomas aka RandomHero (proud V3C-Holland member)
Who can help me?
- RandomHero
Ok, my manual says the relay for the rear foglights is E11. As fas as i know relay E14 is only for the front-foglights. But i'll go look near the steer column to find it. Does anybody know if relay E14 is in the car from stock, thoug it has no foglights from factory?
Thanks for helping so far
Gr Thomas
Gr Thomas
i think it should maybe be in the aux fuse box, near the battery, but i might be wrong
Swapsea-'89 360GLT-swapped!
- RandomHero
- RandomHero
- RandomHero
where was the wiring? i ask cos i'm going to be fitting fogs to my gle next week..
- petefarrell360
- RandomHero
The wiring is under the dashboard, on the other side of the fuse box. Where the wires comes into the car from under the hood. It is a black-white and a blue-red wire. The relay B32 near the battery is the one you should put in yourself. E14 was apparently already there, succes
I think the late style alloys are quite nice. You mean the rims shown on the blue en red glt on the top of this site right?
so you had to put the relay in yourself? i thought this might be the case - how much did it cost?
and one other thing - where do you run the wiring from there - is it already in place or did you have to manually put it in from the fuse box to the lights?
- RandomHero
I got the foglights from a guy i know from the volvo300club, he gave me the relay B32 and the switch with the package. In my car there was already a place for B32 next to the battery. In front of the battery were the 2 cables for foglights binded with tie wraps. The one longer then the other, and they fitted the lights just right when they were in place. If you can tell me how i can add pictures to a reply i will post some clear pics.
