SteveP wrote:Good buy! Check that rear diff gasket/end plate though, it looked like it had the symptoms of leaking.
Got a haynes manual on the way off of fleabay so ill be servicing it and investigating the diff when that arrives. I believe it was you mentioned on retrorides that someone on here sells a kit for the diff end plate, you dont know who do you?
Yeah, mac on here sells the kits.... if you do a search I think I made a post about this a couple of years ago which had the torque settings up for all the bolts etc. If not Haynes should give you the info
