Front springs Diameter?
Baba
Post by Baba »
Does anyone know the diameter of the front springs?
Surely cant be that difficult to find a spring of similar internal diameter from a 4x4 or van to fit.
If I have any luck with this I will share the info lol :D
Post by jtbo »
GLT springs, brand Klien
Length (free):312mm
Outer diameter: 127mm
Wire thickness: 12mm (wire has plastic coating)
Coils: 6,5(4,5 active)
Stiffness: 26,01kN/m
360GL Springs, used 224 000km
Length: 338mm
Outer Diameter: 129mm
Wire thickness: 12mm (wire has only rust, no plastic coating)
Coils 6,5(4,5 active)
Stiffness: 24,76kN/m
Mk2 Escort is rumoured to be usable source for springs, some racers have repored using Volvo 240 rear springs. Either one is unconfirmed, imo.
Baba
Post by Baba »
Wow some great info there. Thanks a lot.
Pardon my ignorance but is the GLT the 1.7 litre version? If thats the case how come the GLT has stiffer springs?
I shall start my quest for stiffer springs today :)
Ronnie
Post by Ronnie »
GLT's are 360's with the heavier fuel injected B19 or B200 redblock Volvo lump. They're top of the V300 range.
Hello and welcome by the way!
http://www.filterfeeder.eu
I have a pair of stiffer front springs for sale in the offers section if you're interested ;)
Baba
Post by Baba »
Steve how much stiffer are the springs? I wanna go stupidly stiff.
Hmm just saw your car, they might not be suitable as they're supposed to run at standard height with the 2.0
Post by jtbo »
Baba, I made spring calculator quite some time ago, it can be useful for comparing different springs as long as they are linear springs.
http://www.janiervast.com/rfactor/index ... lculators/
Ronnie
Post by Ronnie »
Classicswede (A welsh bloke called Dai), supplies springs as low as you like and as stiff as you like, but he's hard to get hold of these days - try a PM
Baba
Post by Baba »
Thanks guys. Any idea how much these springs are?
Thanks
Ronnie
Post by Ronnie »
Baba
Post by Baba »
