2.3 in 360glt
jamie_stafford
Is the engine still in the 240?
The 240 GLT engine runs K jet injection system (mechanical) and sufferes badly from air leaks. Cheack for air leaking past the injectors and check the inlet manfold gasket. The lumpy idle could also be down to a build up of oil on the air flow meter or just fuel mixure settings out.
You will need to keep the old injectors in the head when you swap it into the 360 to blank off the holes. Make sure you fit new injector seals and bucket seals or it WILL leak air
jamie_stafford
the engine is in the 360 and i have it on my glt injection, i have bloked off the old injector holes, i have been fiddleing with it today and i took a pipe of the top of the auto choke (i think thats what it is) to start it and it revs untill i put it back on and it will run on idle perfectley but wont rev, not sure why,
85' 360 glt B230E, 3door, welded diff, lowerd, striped, bucket seats.
To me it sound like the air flow meter has got stuck.wellworth checking
