245 rear springs
245 rear springs
will these springs fit the front of a 360 with a bit of a cut down
http://cgi.ebay.com.au/Volvo245-wagon-r ... dZViewItem
1984 360glt B19 black
They are about the right size so will fit in the cup.As they are towing springs they could be stiff enough. If you are going to do that keep them quite long to start with and then chop back once you know what height the car is sitting at.
My lowering springs are aprox half height of factory when uncopressed!
- filthyjohn
With a std shock they are not captive and need to be clamped in. If a shortened shock was used then that would not be a problem
You would have to go in combination with shortened shocks.
You could pull your apart and get the ends machined down.
To get stiff enough springs and lower something you will not be able to use std length shocks without clamping
Not much to choose from? Just about every state capital has a spring manufacture company that can re engineer any shock to be stiffer and lower, mine cost $260 for a brand new 30% stiffer, 3 inch lower set of heat treated powdercoated springs. If you want cheap, look for MR2 springs, I hear they fit.blackbox wrote:i didnt get them so will think of some thing else just here in oz there not much to chose from
Car will look like this:
Front like this:
rears like this:
1985 - Volvo 360 GLT - V3M downunder! Uprated coils and leafs, Gas shocks, 3A Racing Filter + balls!
2002 - Renault Clio Sport - http://www.ozrenaultsport.com/forum/vie ... php?t=7697
