Wipers
Mills
Wipers
Post by Mills »
All of a sudden they dont work! no movement or washer pump squirting, replaced the fuse but no joy. anyone got ideas??
cheers, alex
Re: Wipers
Post by 340GLT »
Plug on the lever on the column???
morgan105
Re: Wipers
Post by morgan105 »
Dirty contacts at fuse holder.
Loose earth in wiring for switch at steering column (under column surround).
Dirty or broken contacts in switch.
OapEM
Re: Wipers
Post by OapEM »
/\ What he said. The earthing points aren't too clever IMO.
Get rich or die tryin'!
Re: Wipers
Post by classicswede »
Also check the connections to the pump as well
