I have a good B20F i believe the code is? Its a 2.0 8v Multi point injection from a 440. Came out of my mums car that we scrapped due to gearbox failure, very solid engine, would spin wheels in 400 in 1st 2nd and 3rd in the wet. I also have complete engine loom and ecu for teh same engine so a swap into a 300 should be straightforward.
Looking for offers around £200.
2.0 8v Volvo 440 Engine, ECU and loom
- 340GLT
Re: 2.0 8v Volvo 440 Engine, ECU and loom
Very Very easy fit. If you dont want the hassle of wiring in the ecu you can fit the 1.7 carb and manifold.
believe this is actualy the same block as the F3r from memory
Intresting.
And good to know.
*files info away in back of brain for possible future engine swap*
And good to know.
germ
- Location: Hitchin Herts England - South Of France - NI Ards
its pretty much what im doing..it is indeed easy. :)specially if you use the carb set up.. all you have to do ingnition wise is take off the electronic jobbie dist cap(if fitted) take the metal disc and senser out..then wack a rotor arm on and 1.7 dist cap.. eassssy!
Volvo 340
1988
1988Re: 2.0 8v Volvo 440 Engine, ECU and loom
germ, you got any pictures of that? ive got a 1.7 in pieces, so if its that simple i can quickly save those parts if they haven't allready been damaged to fit to my F3R
germ
ill see what i can do mate, i made a lil (rookie) mistake and had to resort to brut force and ignorance..and noone else needs to see that so il pm em
(its a plastic part that is easily replaceable so dont worrie too much guys lol)
Volvo 340
1988
1988
