Collapsed n/s/f Strut
retrocool73
Post by retrocool73 »
Sods law - having just filled up my E-reg 1.4 'shitter' about a minute away from my house the n/s/f starts making some very strange rumbling noise, when I get back I find that the strut cup has collapsed. Jacking up reveals that the tyre hasn't been too badly damaged (due to the distance from home and low speed travelled no doubt) and that a section of the spring has sheared at the bottom. What's the best answer - a new coil spring and weld the cup?
B mk2 1.4GL 3-door57K xSTOLEN PRESUMED CRUSHEDx
E 360GLT Injection 4-Door Red 45K MINT
E 1.4GL 'Special Edition' 5-Door Met.Blue 72K
F 1.7GLE Ltd Edition 4-door Met.Grey 56K
F 360GLT Injection 5-Door Black 106K
G 1990 1.4 5-Door Dark Grey 108K RESTORED
Re: Collapsed n/s/f Strut
D'oh, unlucky with that - it's a horrid problem, especially as you can't just buy new struts so easily anymore!
I'd do what you suggested, new spring (springs really as you should replace both at the same time), and a new cup... George Mitchell sells the strut cups from Friends of the 300. I think Hadrian repair panels might do too!
Post by trabitom99 »
NOR / Klokkerholm still produce the cups:
http://www.nor-as.dk/de/OnlineKatalog/O ... fault.aspx
http://www.klokkerholm.com/e-handel/seek/
Pics:
http://www.nor-as.dk/desktopmodules/nor ... 005430.jpg
http://www.klokkerholm.com/e-handel/see ... er=9005430
EDIT:
Hadrian / Beavers are NOR / Klokkerholm stockists, so you might like to try them. Hadrian has a part on their website called a "front suspension seat" which sound like what you need ...
