Page 8 of 21
Re: The Battleship, Williams powahz, exhaust pics
Posted: 04 May 2009 05:22 pm
by magnumpi
Yeah yor probably right, if i can catch it before it goes as you say cheaper and saves swapping on another diff.
You can see in the underneath pictures there is and had been a bit of weepage going on for some time, i'll get onto it.
Also need new brake pads as the old ones are very nearly on the backing plates, does anyone do green stuff pads in standard fitment?
Posted: 04 May 2009 05:56 pm
by filthyjohn
Black diamond predator pads are available. From elk parts apparently, I have some but I'm not the original buyer.
Posted: 04 May 2009 10:43 pm
by tommysb
That is starting to look nails!
But a question - do side exit exhausts affect performance/do anything apart from looking cool?
Posted: 05 May 2009 12:30 am
by magnumpi
filthyjohn wrote:Black diamond predator pads are available. From elk parts apparently, I have some but I'm not the original buyer.
Thanks for that John, i'll look into it. My Ultralites have gone from silver to looking like they are painted black in 2 weeks or so
tommysb wrote:That is starting to look nails!
Cheers mate. I'm pretty sure a side exit won't affect performance, but i could be wrong, any exhaust experts care to elaborate?
I thought it felt slower at first, but i'm begining to think it's just because it's now quieter, noise= brain equating more speed perhaps?
I only went side exit to try and gain more clearance but i'm thinking now one out the back would have been better for that, but i believe it makes it quite tight between rear axle and body/fuel tank once the rear blocks are fitted.
Posted: 05 May 2009 01:05 am
by magnumpi
i just searched
http://www.elkparts.com/ and they seem to be a Saab specialist, am i missing something, or does a Saab model share the same brake pads as the 300?
Alternatively are you using your ones, want to sell me them?
Posted: 05 May 2009 12:46 pm
by 340GLT
www.needforspeed.co.uk sell black diamond stuff.
Posted: 05 May 2009 06:18 pm
by filthyjohn
Yeah I'm doing my best to wear mine out LOL. The lad I got them off said he bought them from elkparts, but that you had to phone them as they aren't on the site. You could look for performance pads for audi 100s, the pads are the same.
Posted: 05 May 2009 11:09 pm
by magnumpi
Cheers for the link Adam : without sounding a bit retarded (not difficult i know) i have an 89 1.4 so thats what i'd need to order right as they seem to do quite a collection, anyone tried their drilled/grooved discs, could be tempted by those aswell if they are standard size, although not cheap.
Also thanks for the heads up John, i was unaware of that so will now go in hunt of the cheapest upgrade available
Any idea what year 100's as you can get green/yellow/red stuff pads for them. Cheers
Posted: 06 May 2009 10:23 am
by 340GLT
Be weary as i think the audi pads are only the same as the early 300's when they had 2pot calipers...
Posted: 06 May 2009 01:56 pm
by magnumpi
Ah i see, so if that is the case, no good for me.
Posted: 06 May 2009 10:21 pm
by filthyjohn
Ah I didn't know that. Anyone got one of those thick catalogues from a motor discount shop?
Re: The Battleship, Williams, lowering dilema??
Posted: 08 May 2009 12:58 am
by magnumpi
Righty ho then guys, who's lowered their car, hands up i want to see them.
So whats the deal, have i just got the wrong offset wheels? Basically i had my new tyres fitted today, but i've come across a problem.
The front arch has some sort of "block" on the inside which holds the wing, which means if i put my dropped springs on, the front tyres are going to catch on it. How have you got around this, did you just use skinnier wheels/tyres in the 1st place or what? I'm sure i've seen ,loads of lowered 300's on Mimilites or similar, so whats the deal?
Have i just got the wrong offset, i'm confused and quite drunk at the moment, i can't see how it's going to work
If i can't lower it i'm just going to put the stiffer shocks on and see how that helps. I'll get pics up tomo to hopefully explain my dilema.
Posted: 08 May 2009 01:03 am
by 340GLT
I think the problem you are facing is your running wheels with a neg offset so far away from the standard volvo offset, this on a lowered 300 with incorrect tyre profiles is fine because the tyre is nowhere near the arch. My car is on 35mm offset wheels and is fine.
Posted: 08 May 2009 01:12 am
by jtbo
Do it JDM stylee (skip first 5mins to get good part that starts around 6 minutes):
http://www.youtube.com/watch?v=Wxmw-4A0DEQ
He just tells you how to do it different ways first and then he shows easy way to do it, which starts around 6 minutes, good tips there
Posted: 08 May 2009 01:30 am
by magnumpi
Booolacks, so basically i have the wrong wheels
The thing is, it's much better with the higher profile tyres, it doesn't clonk and bang through pot holes anymore, a much more refind ride, but i want it to be lower. Plus the speedo is slightly more acurate.
My mate put the spare/old tyres on to one of the stock rims and i think they look pretty cool, just i like dish, so i presume dish and Volvo's= not compatible?
The vid is cool, good find, the rears aren't an issue, they will roll easy, just the fronts have the wing mounting block so it's not possible i don't think. Put's to bed the Lotus alloys ever fitting then
