Volvo Oil Pressure & Temperature Gauges
- Duvel78
- Website Admin
You are right, it shouldn't be to complicated to wire the voltmeter but you know I prefer electrical connections as it was build by Volvo... I know, I'm a bit "perfectionist" lol
The gauge only is simply to find, for 10 - 15 eur you can find that on Ebay... Example here: http://cgi.ebay.com/ebaymotors/ws/eBayI ... otohosting
V3M for life!
V3M for life!
- foggyjames
No, its that simple (well...its actually wired across switched +12v - ignition, so you can switch it off...but close enough
It uses standard spade connectors, but I'm fairly confident it'll have the wiring. You could buy it from America...but then I can do you a 'bulk discount' with those headlight wipers
- Volvo 360 GL B200K
Just a thought, if that voltmeter was mounted horizontally, when the ignition was switched off, it may not return to its 'off' standard position! I think in some way that they depend on gravity to set the needle when off!
Again i may be wrong - just a thought
- foggyjames
They're pretty strongly sprung actually (if you see mine at the VOC show, you'll see what I mean!), but its a good point. It'd look best to get all three together in a cluster.
- foggyjames
No, but i tested it, and they've all got the same mechanism inside (well...the bit to make the needle move anyway). Put it this way....if you think the ambient temp needle moves quickly...
I thought about putting it in place of the ciggy lighter using a gauge mount from a Volvo 200, but as james says it would take some fettling!
- foggyjames
Ashtray - that's the place to put it. Either that, or use the 3-way holder from a 200 in place of the radio / heater controls / fag lighter, clock, and ashtray.
5lab...how about this?
- Duvel78
- Website Admin
foggyjames wrote:No, its that simple (well...its actually wired across switched +12v - ignition, so you can switch it off...but close enough)
If I could see on a picture where the voltmeter connected is... If the whole wiring is included and can fit without any problem on my 360, it's ok for me... Is it coming from a 300? 200?
V3M for life!
V3M for life!
- foggyjames
The easiest way is to wire it between the heated rear screen switch and ground (either connect it straight to the chassis, or use any brown wire you can see).
I'm not sure how much wire it will come with, so you might have to extend it. It's coming from a 240, but the wiring is the same, and they're the same gauge. To be honest, I'm not even 100% certain that there is a Voltmeter in this packages - I'm waiting on pics in a day or two - but I'm fairly certain there is.
- foggyjames
That's true, there's an ignition line for the stereo (and for the fan speed switch). The installation instructions recommend the heated rear screen switch because its the easiest one to get to!
