Page 2 of 3
Posted: 31 May 2004 04:58 pm
by Duvel78
You are right, it shouldn't be to complicated to wire the voltmeter but you know I prefer electrical connections as it was build by Volvo... I know, I'm a bit "perfectionist" lol
The gauge only is simply to find, for 10 - 15 eur you can find that on Ebay... Example here:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... otohosting
Posted: 31 May 2004 05:07 pm
No, its that simple (well...its actually wired across switched +12v - ignition, so you can switch it off...but close enough
It uses standard spade connectors, but I'm fairly confident it'll have the wiring. You could buy it from America...but then I can do you a 'bulk discount' with those headlight wipers
Posted: 31 May 2004 06:53 pm
by Volvo 360 GL B200K
Just a thought, if that voltmeter was mounted horizontally, when the ignition was switched off, it may not return to its 'off' standard position! I think in some way that they depend on gravity to set the needle when off!
Again i may be wrong - just a thought
Posted: 31 May 2004 07:04 pm
They're pretty strongly sprung actually (if you see mine at the VOC show, you'll see what I mean!), but its a good point. It'd look best to get all three together in a cluster.
Posted: 31 May 2004 07:41 pm
So have u fitted the voltmeter as well as the oil temp and pressure gauges?
Posted: 31 May 2004 07:45 pm
No, but i tested it, and they've all got the same mechanism inside (well...the bit to make the needle move anyway). Put it this way....if you think the ambient temp needle moves quickly...
Posted: 31 May 2004 07:55 pm
by 5lab
couldnt you bodge the place where the clock is to hold it? or the ciggy lighter?
failing that, how about right in the middle of the steering wheel?? gwon, ya know you want to
Posted: 31 May 2004 07:57 pm
I thought about putting it in place of the ciggy lighter using a gauge mount from a Volvo 200, but as james says it would take some fettling!
Posted: 31 May 2004 08:01 pm
by 5lab
just get a clock blanker off a cheap 340 and cut the hole yourself.
Posted: 31 May 2004 08:04 pm
Not wide enough to accept the 52mm diameter VDO gauge!
Posted: 31 May 2004 08:38 pm
Ashtray - that's the place to put it. Either that, or use the 3-way holder from a 200 in place of the radio / heater controls / fag lighter, clock, and ashtray.
5lab...how about this?
Posted: 31 May 2004 09:38 pm
by Duvel78
foggyjames wrote:No, its that simple (well...its actually wired across switched +12v - ignition, so you can switch it off...but close enough
If I could see on a picture where the voltmeter connected is... If the whole wiring is included and can fit without any problem on my 360, it's ok for me... Is it coming from a 300? 200?
Posted: 31 May 2004 09:53 pm
The easiest way is to wire it between the heated rear screen switch and ground (either connect it straight to the chassis, or use any brown wire you can see).
I'm not sure how much wire it will come with, so you might have to extend it. It's coming from a 240, but the wiring is the same, and they're the same gauge. To be honest, I'm not even 100% certain that there is a Voltmeter in this packages - I'm waiting on pics in a day or two - but I'm fairly certain there is.
Posted: 31 May 2004 09:54 pm
by 5lab
you might have to run it off the stereo somewhere - because afaik nothing else round there is running off the ignition - ciggy lighter and clock both just run off the battery afaik
Posted: 31 May 2004 09:57 pm
That's true, there's an ignition line for the stereo (and for the fan speed switch). The installation instructions recommend the heated rear screen switch because its the easiest one to get to!
