volvo 340 GL cvt high revving (HELP)
Re: volvo 340 GL cvt high revving (HELP)
That's AvdA. My Nokia E61 is so slow and old.
That's the one I'm on about. I bought 3 kits from RJ and have them in Glasgow for my cars/ UK stock.
lewy
Post by lewy »
macplaxton wrote:I got some UK stock of the kits £18 posted. As I'm not in the UK, I have get my man that can to do the pics for me of maybe "vermillion" on here can tell you more. He supplies the kits. Search here under "emvk".
Still at work, and can't do much on this phone.
hi can i purchase one of your kits please, (do you have paypal?).
thankyou.
this cvt project drives me mad!!!!!!!!!!!!!!!!!!!!!!!!
No (well shouldn't be) problem. I'll get back to you later in th day. Still at work just now, and need to locate them.
lewy
Post by lewy »
adjusted the belts at the weekend, the gap on one side was 1mm and the other had no gap! so now the revs have dropped just below 3000rpm @30mph, so going in the right direction.
found the web site that sells the EMVK kits (Born Built Beauties and EMVK).
but cant work out how to us it, so still want to buy from you please.
lewy.
Lewy,
I'm still on the warpath to getting hold of my man in Glasgow. If I do get them in the next couple of days, I'll get some more sent over from BBB, as that is where mine originally came from.
Post by volvodspec »
jup, then the fault is in the electrics; do this:
unscrew the EMV and de-solder the diode at one end, now do a resistance check on the coil (should be around 35Ω) and check the diode for blocking in one way. if both of those are fine the tachometric relay has a blown the end-transistor; if it's broken then it probably has blown the end transistor anyway :mrgreen:
and the end transistor is the one described here:
http://users.edpnet.nl/antiekeradio/rep ... relais.htm
good luck!
lewy wrote: so still want to buy from you please.
PM sent.
lewy
Post by lewy »
volvodspec wrote:jup, then the fault is in the electrics; do this:
good luck!
ok fitted a new cvt kit, did a test on the diod ok, tested the ohms on coils ok, tested the end of line transister ok, revs are now running at 2500rpm@30mph so a lot better now, but maybe still seems high, what do you think. (shall start checking vaccums this week end)
Lewy
This page is a useful guide.
macplaxton wrote:This page is a useful guide.
is everybody on here using that page for CVT diagnostics etc? if so, i might be able to do a english translation for a sticky on here? it's a lot better than plowing through 30pages of greenbook though as all usefull info is in it.
lewy
Post by lewy »
well i was using the Green book, and also the info i have been on here that has been so great!. So lets try yours if you do one,
lewy
Post by trabitom99 »
An english translation of that would be fantastic, Google Translator can be a bit of a pain: "Mountain Brake :lol: ". I notice there's something about the kickdown switch on that - eager to know more about that as it's stopped working on mine ... Not that it made much of a difference to acceleration when it did ;-)
allright, i'll start with it then :D
hmm, good opportunity to write the CVT clutch part aswell, i was supposed to do that for V3C ages ago :lol:
