Decent daily volvo
Re: Decent daily volvo
sammysideways wrote:got 5 months in libya so waitings not a problem.
There the sort of car im after sm4 . Chopped lowering springs and some tidy volvo oem wheels and job done
Isnt Libya part of a womans fanny?
Or is that Labia?
Either way dude, good luck. Dont poke any suspicious bin bags.
sammysideways
Post by sammysideways »
im lucky i get to sit off the coast and soak up the rays :roll:
of course were doing very important peace keeping work :wink:
sammysideways wrote:Ok im sold on a 940, anything to look out for on them? common faults?
- Heater Matrix (Pain in the arse dash out job)
- Crinkly front door cards
- Smokey Turbos (and associated turbo car stuff, check for oil feed/drain leaks - although they seem pretty good for not leaking compared to the FWD turbo drain seals)
- Paint on estate rear tailgates can peel
- Rear seats don't fold in a saloon
- Dual mass flywheels can sometimes give trouble, but again fairly rare
They're pretty bomb proof really :) I'd actually say the heater matrix is the worst job to do on one.
Apart from the removal of the dash itself, why is it such a pain? I just have a simplistic vision in my head that you unbolt the whole thing and it'll come away.
Speedy88 wrote:Apart from the removal of the dash itself, why is it such a pain? I just have a simplistic vision in my head that you unbolt the whole thing and it'll come away.
It is pretty much that but personally I'd rather avoid taking a dash out on a daily driver as I reckon it'd take a good half day non stop. Atleast being built well everything should come undone/go back together ok. Tell tale signs are signs of coolant in the passenger footwell. Chesh wrote an article a few years back for VOC:
http://www.volvoforums.org.uk/showthread.php?t=43621
Nice, thanks
The only disadvantage with the 940 is the MPG, 2.3Turbo will only get 25mpg. 850s are a more modern engine and will probably do more, but how the T5R or Ts compare I don't know. They probaly also handle better, but I like the 940, its predicable and strong (stuff doesn't bend).
I will say 940 is a far longer lasting and reliable car than the 850, and the RWD gets the power down much more efficiently in the dry.
Very few common faults, leaky sunroof easily fixable.
Most of the best bits are post 94 (including the fix for the fuel relay which can break).
a.l.2810
Post by a.l.2810 »
Would recommend a 940turbo to anyone looking for a big cheap motor. paid 750 for my '95 estate with 80k on the clock but that was a couple of years ago. Only thing to go wrong so far is the flywheelm but got a good one from a breaker for 50 quid. Think i should have shelled out for a new solid one from ttv racing.
Nobody likes Saloons..... but this is a tad tasty.
'looon
Cheap
72k miles
Up The Daggers.
One Owner
