Re: some problems
Posted: 28 Nov 2012 09:05 pm
for the b19a?classicswede wrote:I have engine mounts and all the bushes.
http://volvo300mania.com/uk/forum/
sweet!classicswede wrote:The 360 mounts are on the way with a couple of other projects this winter.
no bent parts (as i can see anyway) some worn bushes, but looks like changing the steering rack balljoint helped alot, have not had the tracking done, but seems like it goes straight now, and no abnormal tyre ware (yet!)Ride_on wrote:Yes, Camber is not adjustable, so you are looking for bent parts/worn bushes/incorrectly assembled items. The lower ball joint can get bent if you wack a curb, for example.
volvomania wrote:Does the heatervalve still open fully?
What I would do is to let the engine warm up and follow the heating hoses through the engine bay feeling the temperature along the way. Do this also under the dash and you will probably feel where the problem is.
temperature goes to about halfway, where the lightbulb is, dunno how hot it is thenjtbo wrote:Heater valve is in engine bay from my memory at least, just follow heater hoses, those thick black ones that go to heater box, it is attached to one of them hoses.
It can get clogged or it can be that cables moving it are not operating very well.
How is your engine temperature after replacing thermostat?
We have -30C days now, so people are putting cardboard covers to their car fronts.
Summer diesel in french crap's tank is not in liquid form anymore, so must wait spring to drive again
I don't think it is worth to un-clog it, probably just starts to leak next, but new one should not be very expensive and I think those are still available from parts shops. I have image in my head that it would be easy to swap, but it can be wrong image, anyway I think it was below heater box above bellhousing, somewhere there that valve, but indeed my memory is not too great and can be wrong on this one.tim-andre wrote: temperature goes to about halfway, where the lightbulb is, dunno how hot it is then
is the heater valve easy to un-clog?
people do that here around minus 20![]()
but i think i would have had a problem if it got that cold, my lungs dont work when its that cold![]()
a friend of mine already has some problem with his french diseasel, wont start anymore, volvo keeps on going thou!
maybe haynes will have the answer, when i figure out what heater valve is in swedish (i got a swedish haynes manual)jtbo wrote:I don't think it is worth to un-clog it, probably just starts to leak next, but new one should not be very expensive and I think those are still available from parts shops. I have image in my head that it would be easy to swap, but it can be wrong image, anyway I think it was below heater box above bellhousing, somewhere there that valve, but indeed my memory is not too great and can be wrong on this one.tim-andre wrote: temperature goes to about halfway, where the lightbulb is, dunno how hot it is then
Too cold to go look, also there is snow on top of 360 as it is not in garage, because there is house related project going on at the garage, so can't check now.
Most annoying bit is perhaps those cables, especially on cold, one can't use warm gloves either on that job and generally very annoying cold, tiny, hard, sharp cables that are probably tight, so in addition of freezing hands there will probably be some cuts too, then if engine is hot also some burns to exhaust manifold too, that is usually what happens to me, not difficult really, just annoying
okay, you got me, im lazy, i have not opened the book yetjtbo wrote:Värmare ventil, not too far from varmeapparat ventil, but I'm not sure if that is bokmål, nynorsk or kvääni, however I think kvääni was northern language?
That is just what translator spite on me.
Jeg får værmeldingene fra yr.no, so I know only few words and very little swedish, should learn more actually as there are some things I have not been able to read because of this limitation.
