Page 2 of 2
Re: 340 1.7 carb dont work!
Posted: 16 Apr 2013 03:02 pm
by Busicrx
Jejejeje only 10 days? To me seemed a life!!!
Posted: 17 Apr 2013 11:34 pm
by Busicrx
Pfff other problem! I lost the screw that fix the green block new ruber gasket to the carb. It is important? If i dont put this screw? Thanks
Posted: 18 Apr 2013 09:18 am
by mac
No - as long as block and rubber shim are in correct position when bolting carb down.
Mac.
Posted: 20 Apr 2013 01:39 pm
by Busicrx
Mac, you know where i need to conect the econometer tube?? Thanks
Posted: 20 Apr 2013 03:07 pm
by mac
Any source of manifold vacuum will do - I would suggest a "T" piece into the crankcase breather line to the large take off on the green block (the one you transfer over from the OE black block). You'll need a T with the appropriate sized pipe stubs but shouldn't be hard to find. You could also T into the line to the brake servo.
Mac.
Posted: 20 Apr 2013 09:59 pm
by Busicrx
Ok thanks!! I take the T from the car that i take all jejeje. (I live near a "place were are a lot of crashed cars"
www.desguaceslatorre.es ) i think in the brake servo is good! Thanks.
Other thing, the green blocks weaks?? And what glue i need to use to the take off that i need to change from OE to green block, cause he dont fit so tightly. Thankthankss!
Posted: 21 Apr 2013 09:28 am
by Busicrx
Mountingggg
Posted: 22 Apr 2013 07:30 pm
by Busicrx
Yyyeeaaah!! All mounted!.. How many turns to adjust the "CO" screw in a aprox. "standart" position, ahh i have a k&n replacement filter.
Thanks!
