Cheers Adam
Front suspension bracing
Sirnixalot
Adam and myself have talked about this. I must get on with it post the rest of the pics.
That does look good - I bet you can feel the diference
- 340GLT
Speakin of which here is some pics of my progress.
The crossmember is now fully stripped and sandblasted. It is also fully strengthened, although looking at those wishbones i might be doing that too!!!
Here are the pics of the sandblasting done, strengthening pics to follow 2moro nite!!!
Cheers Adam
Complete crossmember from a H reg car
Cheers Adam
Looks loads better after a goob blast
- 340GLT
Yeh cleared all the rusty patches off and they are like new. Strengthened all the spot welds by seam welding the crossmember with gas torch, then migged the back of the turrets where they rot and also beefed up other welds with the mig!!!
Boy is it tough now. I thinks i'm going to box in the wishbones now after seeing those altezza ones.
Cheers Adam
Cheers Adam
- foggyjames
Excellent work guys
Damn I need to learn to weld...
ditto your comments foggy!
I was learning to weld here at a college in manchester in the evenings but had to give ti up coz of tto much uni work
hpfly next year I'll do the course again.,.
COOL work Adam! I like part where you have seam welded along the old welds to strengthen....
Ive got a rear suspension I was to recondition... and your post got me thinking... basically... is it a good idea to put new seam welds along and over the old joins/ welds in the suspension after its all clean of rust.?? afterwards you paint it all...
Where did you get the sandblasting done?
Shimon
Shimon
Enjoy your 300s
- 340GLT
Yeh its good to renew the welds as most parts are only neatly welded to hold them not for strength.
My mate has a compressor and sandblasting equipment so we made a good mess outside his house!!!! lol
Cheers Adam
Cheers Adam
I started welding when I was about 12. I can now use mig, arc, tig, gas and even plastic welding! It is very handy, the only problem is when you can do it well it bugs you seeing poor welds.
- 340GLT
I just finished my arms off tonight. Will post pics of them with poly bushes too. Will try and get pics 2moro, if not it will be Monday.Sirnixalot wrote:if anyones thinking of doing this, box in the control arms at the same time
Cheers Adam
- 340GLT
Finally got round to posting pics of the new arms boxed in, fitted the poly bushes i got from Dai too tonight and made a strut brace for the back in this link!!!
http://www.volvo300mania.com/forum-uk/v ... 1708#31708
Cheers Adam
Cheers Adam
