Page 2 of 4
Posted: 31 Jan 2006 03:03 pm
by Jay340
looks like two bolts facing the opposite way, are you saying on the reverse of these is an allen key hole??
Posted: 31 Jan 2006 03:08 pm
by Jay340
just checked, there is no allen key holes in these boltts, there just the same as the top bolts although they are facing to opposite way..
They look like 14mm bolts.
Posted: 31 Jan 2006 07:12 pm
by 340GLT
This is to remove the rear engine mountings yeh???
Cheers Adam
Posted: 31 Jan 2006 07:13 pm
by Jay340
nope bottom bellhouse bolts, the engine mounts where the next job
Posted: 31 Jan 2006 07:19 pm
by 340GLT
Ah right, have you removed the small inspection panel from the lower half of the bell hgousing looking from front to back?? Most of the bolts you can get to, however IIRC one of them is a real PITA and you need a universal end or a wobbley end To get on to the bolt!!
Cheers Adam
Posted: 31 Jan 2006 07:32 pm
by Jay340
inspection panel?? i can see the 2 bolts quite clearly but the cross member/steering rack are in the way so that i cant get a socket or ring spanner on it
Posted: 31 Jan 2006 07:57 pm
I have this joy to come...
Posted: 31 Jan 2006 08:01 pm
by Jay340
foggyjames wrote:I have this joy to come...
take the engine out!!!!!! if I cant sort this tomorrow it will sit till the weekend when I can Hire a hoist to do it... i would rather get it done tomorrow though so I can drive it
Posted: 31 Jan 2006 08:07 pm
by 340GLT
Inspection plate only has two bolts in it
Cheers Adam
Posted: 31 Jan 2006 08:10 pm
by Jay340
340GLT wrote:Inspection plate only has two bolts in it
Cheers Adam
you will have to explain it all mate, I hate mechanics and so dont normally get under cars.
if its about spraying then im here to help..
Posted: 31 Jan 2006 08:12 pm
by 340GLT
Right directly behind the crossmember from the front you can see a small plate attached to the front side of the bell housing you need to remove this
Cheers Adam
Posted: 31 Jan 2006 08:18 pm
by Jay340
340GLT wrote:Right directly behind the crossmember from the front you can see a small plate attached to the front side of the bell housing you need to remove this
Cheers Adam
all that I saw while i was under there was the cross member and the 2 bolts on the bell housing. an in if your were under the car with your feet to the back.
Posted: 31 Jan 2006 08:30 pm
Don't mean to insult your intelligence Adam (but I'm going to anyway sm56), but you know we're talking about the 1.7, right? I've never looked in detail at either, but it sounds very much like you guys are talking about two different engines...
Posted: 31 Jan 2006 08:32 pm
by Jay340
foggyjames wrote:Don't mean to insult your intelligence Adam (but I'm going to anyway sm56), but you know we're talking about the 1.7, right? I've never looked in detail at either, but it sounds very much like you guys are talking about two different engines...
Doh
Posted: 31 Jan 2006 08:43 pm
by 340GLT
Both engines layouts are basically the same and both have an inspection plate at the base of the bell housing!!
Cheers Adam
