340 Bigger engine
Re: 340 Bigger engine
Post by redline »
petefarrell360 wrote: get a prop made up, or use the 360 which had a torque tube, which is significantly stronger.welcome and enjoy V3M.
foggyjames wrote: you'll need a 360 drivetrain (you could use a 340 setup with a stronger prop, but it's more expensive, and you'll need an adaptor plate made up for either)cheers
and we all know where theres a nice cheap 360 going , dont we lads
Andrzej
Post by Andrzej »
obviously if i were to take this route i would be junking the rubber band system. and using a proper auto box
but would be keeping the rear axle just for the cheap ness but would be a semi daily driver as i also have a 2nd generation chevy camaro weekend kinda car with a baby 3.8 ltr v6
so thats why the idea of plonking in a 6 or 8 as they are cheap enough and if you want bur out ability then thats the way to go!
but what can be done to the classic no frills 4 pot over head valve machine to spark it up a bit even with the auto box? just out of intrest
Our 340 cost us nothing! freebie scrappy saver
If you're going to use a gearbox that comes with the engine, and assumingly do some hacking of the transmission tunnel and have it front mounted... then I can't see it being possible using the rear axle of the 300 because of its original transaxle layout.
Andrzej
Post by Andrzej »
But would i be correct in assuming that the connection after teh rubber band system is londitudually connected thus still having a centeral connection ie one straight line from engine to axle in the form of propshaft and rubber band cotton reel system.
Soo if you negate teh elastics then plug straight into the rear axle?
arnagath
Post by arnagath »
I saw couple years ago in finnish hotrod-magazine an article.One guy had putted in his 240 wagon Volvo a small-block V8 chevy engine sm71
It was awesome!! There was still extraspace in engineroom...
Exterior were original-look except 17" alloy wheel and douple exhaust in back.True sleeper :twisted:
And ive seen many VW beetles/bugs with V8 fitted in front of the car..
You might have then first Volvo 340 with V8 in europe or in world :D :D
Sorry,went a bit off-topic :lol:
Volvo 340 GL `87 B172K +
Volvo 360 GLT `87 B200E =
Volvo 340 GLT B200E *sold*
Volvo 245 `86 B200K
You could use the old rodders fav the jag IRS on the rear.
Andrzej
Post by Andrzej »
the old custom chrome irs would look sweet but too much work to convert from leaf rears with over sized tyres and the other usual rodders favorite the volvo rear axle as has been used in many a custom rod.
since the volv can take a lot of stick and more, so if its there why throw it out!
PIMP
Post by PIMP »
rover v8.....£250
lt77 box (sd1 manual)...£100
ford english axle assembly....£100
new prop....£200
me to fabricate engine mounts,gearbox tunnel, fit axle wire up etc....£1000
job done fella!!!!!! :lol:
put rovers in loads of cars and trucks!!! and i think its lighter than a 1.7 as well cos its all alloy!!
go on dont be shy!!
Andrzej
Post by Andrzej »
Why would i want a manual gear box? when the car is already automatic!
would prefer to stick with the auto box
So your saying for a grand you can supply the lot and make it happen :?: if im reading that correct :?:
Or is the grand for teh tunnel work would prefer to keep the inside as std as possible to make it look a street sleeper :)
volvorsport
Post by volvorsport »
the PRV v6 has been fitted to a 360 that i know of.
for a grand , you should be looking for a new car , not beating an old340 auto to death , unless you want to get rid of every last bit of drivetrain
Andrzej
Post by Andrzej »
Whats wrong with spending money?
we all have to some time or other!
ok it is a bit ott but then how much is spent on hot rods and custom cars in the uk and besides if i sell my 3.8 v6 1980 chevy camaro what am i going to replace it with ehy!
volvorsport
spending money isnt a problem , the diff and everything else will not take the torque .
A big banger 4 pot , would be just as quick as the v8 , although not sounding like on obviously .
if you do go for the V8 youll need range rover headers as theyre much tighter .
i dont think the diff can be seperated from drive belt section successfully to be used - so you ll be looking at doing something there aswell .
volvorsport wrote:for a grand , you should be looking for a new car
Really? A grand of which (and more) will be lost on a new car within a year of depreciation.
Stuntman
Post by Stuntman »
Who needs new cars, say for example buying a second hand decent fiesta corsa, £3k, the would buy you any decent volvo and have a lot left for personal touches, say £300 300 series, £1500 for engine drive train and brakes, then £500 for wheels interior and sound, and the £700 left for insurance and running costs!!
Erm, I've lost my keys again...
MJ
Post by MJ »
The only disadvantage is that they arn't quite as safe as newer cars, although being bigger, I'm sure that they'd rival some competitors such as Ka's, and they're much safer than equivilents from the same time.
And RWD :) If only running a car wasn't so expensive, I'd have my own 300 straight away :(
