360 engine mounts?
- RandomHero
- antiekeradio
- Tero Huikko
http://www.scantechsweden.com/
they have two different mounts...but I have no idea how or where to order them??? Also the pricing is a mystery...
Older 360's had all-rubber-and-no-fluid mounts. Are they replaceable to newer 360?
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
Volvo V50 1.6DRIVe 2009
Mercedes-Benz 190E 1992
Oldsmobile Omega 2.8 V6 1981
Volvo 66 GL 1977
Volvo 440 DL 1994
- antiekeradio
how do you mean there are two?
only one I can find is this one:
Engine Mount, LH/RH
Engine Mounting
MakeOfCar: VOLVO
Part No:51.6524
Model: 340/360
O/E ref: 3286524
Category: Engine
Application :
Engine: B19, B200
Year: 1983~91
its the right one, I don't think there have been other models (1983 is introduction of the 360 name, technically there was no big change then)
Engine Mount, LH/RH
Engine Mounting
MakeOfCar: VOLVO
Part No:51.6524
Model: 340/360
O/E ref: 3286524
Category: Engine
Application :
Engine: B19, B200
Year: 1983~91
- RandomHero
- Tero Huikko
There's a second one in the engine parts PDF. Only one in the 300-series PDF. The other one is "reinforced".antiekeradio wrote:how do you mean there are two?
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
Volvo 66 GL 1977
Volvo 440 DL 1994
- Tero Huikko
No I'm not sure. This is what I've been told. ???RandomHero wrote:Are you sure about this? As far as i know the early 345's with B19A engine's already had the type of mounts like on that pciture above.Older 360's had all-rubber-and-no-fluid mounts.
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
Volvo 66 GL 1977
Volvo 440 DL 1994
- RandomHero
You're right! I've found out in the parts cataloque that there are in fact two types. They're both filled with fluid but the second one is heavy duty. So this one is probably for the models with power steering i guess. I also found out that the little strip under the engine mount is also an original part. I made it myself, but the idea was bassed on an excisting part.The other one is "reinforced".
- 360 GLT, 1989, Gray Metallic, 115.500 km, PAS, Electric Sunroof, Windows and Mirrors
- Tero Huikko
- RandomHero
- Tero Huikko
So I understand that the reinforced ones aren't too stiff for daily driving? Noisier etc?pettaw wrote:I put the 'reinforced' ones on my non-PAS car and they looked identical to the ones that came off........
Volvo 66 GL 1975
Volvo 66 GL 1977
Volvo 440 DL 1994
Volvo 66 GL 1977
Volvo 440 DL 1994
- RandomHero
You mean the exhaust brackets in the back of the car right?
But if the engine sits about an inch higher that confirms my thoughts about the PAS. Because a 4 mm strip on the exhaust side, and 6 mm on the intake side of the engine was enough to solve my problem with the crankcase hitting the PAS rack.
