volvo 340 1.7
now this is interesting mate,
does the 440 gl carburettor bolt straight on to the manifold ??
in that case i should have some good gains out of it as my 1.7 seems to produce the same power as your 1.7 with a better carb ,if you know what i mean ???
so in that case i shall get around 100bhp with that carb ,what make is the carburettor ???
The carburator is Solex, but what changes is the dimension of the jets... The bigger they are more fuel you inject.
For example the Solex that the 440 GL uses is 97.5/140
The 340 1.4 is 120/135
The 360 is 120/115
The Renault 5 Gordini is 140/165
The 360 is 120/115
| 92' 965 Turbo 16v | B204FT - 190hp |
Had: 90' 340 GL + Turbo | B18 FT | Koni's | Alpina White |
Why 360 2,0l has smaller than 1,4l moped engine
There is certain limit how big you can make jets as there is carb throat and it can deliver just certain amount of air now you would like to have air 13 times more than gas to get best power, figure out throat size and maximum amount of air that can pass trough and you can calculate maximum size for jets.
There's a guy here in Portugal who has a Clio with the 1.7 engine
He wanted more power, and what he do was buy a Sierra 2.0 weber carburator, change the jets an dsomething related with te air in the carb..
The car was running pretty well and very fast
Maybe part is shown in here?
http://www.janiervast.com/gallery/v/vol ... k.jpg.html
- foggyjames
Putting a larger carb on and having it rejetted is probably a wise move for a mild upgrade. Stick a longer duration cam on while you're at it, but bear in mind that this will make your car more rev-happy. If you have tall gears, that might not be a good thing.
My car was pretty awesome down low with the original cam in it with the huge carbs.
