spot lamp brackets
5lab
Post by 5lab »
hers popped out under the front grill, to hold some lamps where the early 300 spots were. didnt look origional, and no lamps, so i removed them.
Post by redline »
doh ! , dos removed = threw away ? I only want one to use as a pattern
5lab
Post by 5lab »
yup
Post by redline »
bugger
Post by redline »
Finally got round to making a set of spot light brackets using the plates that go behind car tow balls for the double electric sockets, they look pretty tidy and are screwed directly to the bumoer iron (after bending 90 degrees ) so should be quite solid
Post by redline »
finally got some proper spot light brackets ( thanks Hugh ) will post pictures as soon as I can
