meintag's 360 photoshoot !
- petefarrell360
Thanks all !!!! I'm glad you enjoy it
Are a VERY lightweight alloys, and a bit shorter gear ratio with 175/50 make this:
http://www.youtube.com/watch?v=ByO_QzlH06w
I'm a bit surprised/scaried
What you think guys ?
Regardssss !!
Regardssss !!
- foggyjames
Beautiful!
Well... I haven't a single topic which I can update like a 'Project topic', so... I'll update this
The car was stored since July or so due to very different issues... Not time enough for it, troubles with international shippings, etc...
The last I made for the car was to chop the stock springs and fit some cheapos dampers from Ebay ---> Catastrophic. Car runs million times worse that in stock form...
I bought some stuff from Dai and parts here and there. Is now when I start to fit everything !
Due to the lowness, I'd hit a bump with the ARB, bend the crossmember and break the ARB balljoints ! A visit to my local scrap and pick new items ! Add some polybushes from Dai and go !
I think those fasteners need a reshape after the hit...
Half and hour later... Fitted !
** Time for a break **
- foggyjames
I see an AC compressor
Feel good to be back on the wagon?
The upgrade include Classicswede front springs too to throw faaar away the chopped ones... I use my old Gabriel gas dampers, I'm not very confident about the r-sports I bought recently in Ebay. I'll take them to a 'shocks dyno' to test...
Directly to the bin !
Wow, the stance is the same that before ! You'll see the light very soon, baby !!
The operation was surprisingly quick, thanks in part to a new balljoint splitter
( 25 EUR best spend of the year ! )
I decided then to raise the bonnet a bit... Some extra cooling is good when you spend 1 hour of abuse in 2nd gear ! Very easy, just adding some nuts and washers to bonnet retains and a longer stud !
This is the result, and first light of the day since July... Dirty, with headlight's crosses hanging...
Poly bushes were sight from miles ahead !!
The following the rear side... New oil for box and diff, a new welded one, lowering plates and Spax adjustables !
That's all folks ! Greetz from Spain !
