Latest parts victim
Yes ;)
Off you go then :P
Ronnie
Post by Ronnie »
Chris_C wrote:Aleks was told that front wheel bearing kits were unavailible a few weeks ago, I don't know if mk2's are different
It's the same part across the whole 300 range, and possibly Daf too. I had two over the summer without problems
http://www.filterfeeder.eu
shimon340
Post by shimon340 »
hi
I know the rear wheel bearings are the same for the volvo 66, 343, 340 and 360 :)
volvo OEM were SKF bearings (bit of history there too!) and are still available from SKF. fortunately, there arent complex bearings with carriers etc so aftermarket versions arent difficult to source.
the hassle with all this is that whilst you can get parts, its not so easy as calling volvo and the part coming the next day
companies like nordic are picking up the baton for after-volvo parts and genunine classic parts (volvo has a holding is this company and helped set it up, still works closely with etc before ford bought volvo in 1999) also supply
however, just as when this website was started, the 2,7,9 and 8s plus 120, 1800,140s etc all have good support, the 300 series doesnt have such a following so less swedish companies etc supply parts.
as discussed before, this website is a good place for posting alternative part and their supply
just need to get an advert in every dealer so we really get noticed!!
work of people like Dai and Mac is just EXCELLENT!
Enjoy your 300s
Yay... add 1.7 top and bottom hoses to the list. Both of mine have now gone pop in 3 weeks, still, at least its getting regular flushes and antifreeze changes...
Found a place in Soton that seems to make custom hoses, so gonna take my old ones in later
Post by trabitom99 »
Funny you should resurrect this thread today Chris, only this morning I was back at the Volvo parts desk. Water pumps are indeed, no more.
Still available however was the original door key (only the simple model, not the one with the built-in light) and alloy wheel nuts, which I'm picking up on Monday ...
Fuse
Post by Fuse »
Makkiver confirmed that a water pump from a bigger Volvo with redblock engine will fit, even if the viscous fan is used. He's had two engines with a pump from a bigger Volvo and no electric fan. Of course the 300-series viscous must be used. So there's no problem with that.. :P
And if you use a pump from a bigger Volvo, make sure that you get the right one because B19/B21/B23-series has a different pump than B200/B230-series. :P (Water passages are in different places)
Well, going by the part number I've got the wrong one (B19) fitted in my B200F. No wonder it overheats ...
Now all I need to decide is whether to get an aftermarket B200 one from QH or SKF (around 65 Euros) or an OEM one for a B230 (95 Euros) ...
I suppose using a 2/7/900 series one would work...although it reduces clearance for an e-fan even more!
Have you written a strongly worded letter yet foggy? As VOC 300 register keeper... :lol:
Not yet....I'm letting my scorn simmer for a while ;)
Nikdev
Post by Nikdev »
classicswede wrote:I alsos had some not so long ago. If they have been dropped then I can see my solid mounts becoming more popular.
Witch solid mounts????? :?: enlighten me :D
Haven't heard you are selling solid mounts
foggyjames wrote:...although it reduces clearance for an e-fan even
Hmm, that might be an issue as I'd like to fit air conditioning at some point. There's probably little enough space as it is, with the condensor in place, even with the slimmer radiator fitted ...
Well the condenser goes in front of the radiator...but...you need a more powerful fan to cope with the extra heat! The only unit I found which would flow enough air and be thin enough to fit (with a 360 WP) was a Kenlowe unit at £125 :shock: ...that's just the fan...not a 'kit'...!
The green book says the original air con systems weren't fitted with the extra fan and recommend retro-fitting ones due to temperature problems.
Did you have problems mounting it, if it didn't come as a kit? According to the book it should come with mounting brackets to fit it to the condensor, a thermal switch, relay (with bracket) and fuse ...
