Ambient Temperature Help (now with m0ar need for help!)
mac
Post by mac »
fj - did you sort a 't' piece out ok?(for your B14 vac gauge) If not PM me yr. address and I'll pop one in the post (I've got about 4 "genuine" ones in stock).
Mac.
Post by filthyjohn »
Mac that's awesome of you, I'll PM you my addy as a genuine one must be better than the manky bodgepipe I had lined up for the job.
To clear it up, this is the breather pipe I need to intercept, oui?
Cheers!
mac
Post by mac »
No probs,
Yes - that's the pipe ok - BUT it is fitted with a restrictor very close to the carb vacuum souce - the "approved" way of fitting the 't' piece is to take the pipe off the carb, fit the 't' to the pipe then join the 't' to the carb using a short length of pipe (50mm) cut from the rocker cover end. (have a look at the instructions - they're posted in the tech section). The 't' must be fitted between the restrictor and the carb - or you'll get false readings.
PM on its way.
Mac.
Got ya, I shall do just that as soon as I can muster the enthusiasm. I've just spent a few hours replacing all the brakes on the daily 340, so I can't really stomach the thought of any more effort. :lol:
SORTED cheers folks. The vario now has a shiny new MOT, so I can get stuck in to sorting the blue one out.
sm80
