Driving Computer / Cash Register Installed!
- 340GLT
Hi Foggy, i was just wondering if you had any more info on the fuel flow device used on the computer? I have just fitted the comp to my 340 knowing the fuel flow device wasnt there. SO i can as you know only use the speed and distance functions. The comp i installed was originally fitted to an injection model from new but was taken off after a few months as it became faulty. The fault was traced to the control box measuring the injectors. And so my uncle found it the other day and gave it to me. Hope you can help.
- petefarrell360
- 340GLT
Yeh i was lucky, as my uncle was master technician at my local volvo garage! So he has given me loads of stuff for my car including anything i wanted off his 360GLT he has in his garage with accident damage! Its nearly where i want it!
Not much left to do!
- foggyjames
I've posted in the other thread....but you say here the injector buffer amp is faulty? Bummer!
- RandomHero
I'm a Random Hero, so obviously i got myself one of those computers too LOLyou're a HERONobody here has that wonderful technology in a Volvo 300!
Unfortunately, i don't have the sensors and the bracket thingy to the dash. But i set me back only € 7,50
- 360 GLT, 1989, Gray Metallic, 115.500 km, PAS, Electric Sunroof, Windows and Mirrors
Ahhh, I hadn't found this thread, hmmmm, much needed info!!!
Re: Driving Computer / Cash Register Installed!
Just been reading the old posts re taxi meter fitting now that I have one
I bet he never realized how relevant that last statement would become in later life lolfoggyjames wrote:
Anyhoo....down to business....
You lot presumably all know what this thing is all about! You can probably guess what it can tell you from the buttons..
.shame 'range' isn't there - all you'd need to know is the size of the tank.
- RandomHero
I got range
Mick, if you want, I might be able to give you some pointers fitting wise on Tues, but I'm sure Foggy and Adam will know exactly. I am dead keen to see what the fuel flow sender looks like, even though I'll now be putting mine onto an injection engine, it'll be useful if I'm going to make a how to.
- foggyjames
Mick....just a thought...have you found the link for my blue-book installation manual for the driving computer yet?
- 340GLT
Is there no manual with it Mick??? I can prob dig out the instuctions for ya!!!
Basically you can do a couple of things in preparation for fitment!!!
Fit speed sensor to diff casing and fit flow sensor on a bracket under bonnet somewhere. You can mount fuel lines to this too as it doesnt restrict fuel flow. On the sensor earth the green cable. From memory there is an orange and white wire also on it, they go to same colour wires on comp loom.
Also on the comp loom you have to tap it into the ignition live and put a spade to the back of the dash lighting dimmer and connect two wires to the sensor!!!
I think thats about it!!! I did it all in about 2hours when i orignally did mine!!!
Cheers Adam
Cheers Adam
yeah thats what I thought
must admit I am so pleased with it , still in the original box and it even has the protective film still on the screen
- foggyjames
Told you it was new
Here are the instructions, courtesy of Chesh....
cheersChesh740R wrote:
