340 GL breaking for spares
Re: 340 GL breaking for spares
Post by trabitom99 »
Cheers mate, thanks :-) There's a black plastic thingy which goes between the belt housing (erm, the part where the seat belt rolls up in) and the C-pillar - it keeps the housing at the right angle when you're putting the bolts in, if you could save that piece, that'd be great too ...
340ovlov
Post by 340ovlov »
Chris_C wrote:Can I be a real pain and ask for some small tarting up bits for my new GLT buddy.
*Bulb holder for behind the light switch (same as behind the heater controls and behind ashtray, but a lot easier to get too)
*Bulb holder for windscreen washer switch (same as hazard/rear screen heater/rear fog switch bulb holders as I don't think a 340 of this age will have that...)
*Heated seat rocker switch (whole panel if its going would be great, again if the car has it).
*Hazard switch complete with plug and 6" of loom
Cheers dude
i have removed these now if u still want them pm me and we'll get them posted asap
1985 340 1.4 3door
340ovlov
Post by 340ovlov »
trabitom99 wrote:
340ovlov wrote:car has got to go by 28th of this month as someone has complained about it being in the garden ...
bloody neighbours :-(
I'd be interested in a heater valve (Haynes calls it a "water cock" I think :oops: ), and a rear seat belt (left or right, doesn't matter) if you've got time to remove them and post ...
can u explain where the heater valve is please then i can get it out for u
1985 340 1.4 3door
retrocool73
Post by retrocool73 »
If the rubbing strips are decent can I have those?
B mk2 1.4GL 3-door57K xSTOLEN PRESUMED CRUSHEDx
E 360GLT Injection 4-Door Red 45K MINT
E 1.4GL 'Special Edition' 5-Door Met.Blue 72K
F 1.7GLE Ltd Edition 4-door Met.Grey 56K
F 360GLT Injection 5-Door Black 106K
G 1990 1.4 5-Door Dark Grey 108K RESTORED
340ovlov wrote: can u explain where the heater valve is please then i can get it out for u
On a 340 it's inside the heater box AFAIK. I'll get a pic from the parts catalogue if it helps ...
The part itself should look like this:
http://i4.ebayimg.com/04/i/001/30/27/020b_1.JPG
Tom, do you want the hot water controlling "tap"? If so, thats a black inline valve with a bowden cable going to it just above the bellhousing on the 2 pipes going into the bulkhead.
Have pm'd you about my bits dude
nomead
Post by nomead »
There are two different part codes for the valve in VADIS... so they may be quite different depending on model year.
3297723 up till chassis 089537
3211645 CH# 089538 on
Too bad the catalogue seems to have only one sort of picture for it.
Volvo 340DL Variomatic -89
Volvo 360GLT -86
Yes, I saw the different part numbers, and hoped ovlov's might be the right one, as it looks like an earlyish MkIII ... Chris, you're right, that's where the valve is placed on my 360 too, but on my 343 there's no sign of it (or the cable controlling it) in the engine bay, so I figured it was probably in the heater box ...
Here's the location of it from the 80 - '84 parts manual:
EDIT: control valve 1 in red, control valve 2 in blue
Post by filthyjohn »
Oh man! That looks easy to change! Not!
340ovlov
Post by 340ovlov »
i've found a place to keep the car now so i'll be shifting it from mine to the lock up this week and i'll have a go at the heater valve then at the weekend when i get back from oulton park drift day
1985 340 1.4 3door
Duvel78
Website Admin
Post by Duvel78 »
PM sent for some parts! :D
V3M for life!
340ovlov wrote:i've found a place to keep the car now so i'll be shifting it from mine to the lock up this week and i'll have a go at the heater valve then at the weekend when i get back from oulton park drift day
OK, cheers mate!
nomead wrote:There are two different part codes for the valve in VADIS... so they may be quite different depending on model year.
I just had another look at the parts books, there are three different types of heater control valve:
3269730-2 CH -347999 (the early brown daf dash by the looks of it)
3297723-3 1980 - 1985 CH -089537 (up to August / September (?) 1985?)
3211645-1 (3209861-8) CH 089538- (mid '85 on)
and then there's a second type of control valve 3275263-6 fitted from CH 348000- to 1984 (circled in blue in the above pic)- just to confuse things a bit ;-)
340ovlov
Post by 340ovlov »
the one you have cirlced in red tom is the one fitted to the car its very simple to remove all i hav eto do is cut the water pipes and remove the cable connected to it 2minute job
1985 340 1.4 3door
If it's that easy to get to, it may be the wrong one, on mine you can't access it without taking the heater box apart. But I'll take it off your hands anyway, it'd be good to have a spare for the 360!
