Yes, you need to change gear ratios weight and all according to car spec, also wind and downhill affects to measurement.
You should have 3,64 diff and gears same as mine, maybe drivetrain loss is bit less, mileage affects to that and many other things.
Drivetrain loss is what I used to tweak when other values were right, I adjusted it so that it looks approx correct torque.
When first tuning is ready one should not tweak it anymore.
Of course temp and all enviromental values should be adjusted according to test weather.
Example from rolling road, when they sell you k&n and show curves before and after, it is often that for after curve ambient temp value is set higher so dyno shows more power
That is why I'm usually saying that dyno curves are not precise, they show change to power pretty well but it is just impossible to measure true power output on rolling road, it is always more or less estimate.
Also what gear is used is making quite a lot of difference, so many variables to handle
According to finnish manual 1,7l specs are:
80hp(60kw)@5700rpm
131Nm(13,3kpm)@3200rpm
Weight 983kg/1002kg 3dr/4dr&5dr with fuel tank empty, need to calculate a bit, driver weight must put there too.
But I think that drivetrain loss is one to change, if you put it 0% then you get wheel power, not engine power. My value is taken from one race 360 that had it measured, but I'm not sure if that is still correct for my car
