360 LSD.
|2aebird
Re: 360 LSD.
Post by |2aebird »
Excellent, just let me know when you have it sorted and payment details and I will get the money to you.
|2aebird
Re: 360 LSD.
Post by |2aebird »
Any updates on what's happening miniswift?
miniswift
Re: 360 LSD.
Post by miniswift »
Hi,
I'm waiting forour Swedish friends to come up with what's faults there are.
Then I can send info to my supplier to get it fixed from next batch.
How soon do you need?
Atchi
|2aebird
Re: 360 LSD.
Post by |2aebird »
Not in a huge rush, I would much rather get a product that has been sorted properly than rush you and get an unsatisfactory product, just trying to keep up to date as I'm not on this forum all the time.
perkabrod
Re: 360 LSD.
Post by perkabrod »
Hi! I'm the Swede no. 2 and just wanted to chime in and say that my diff that arrived in may 2014 also got 1.5 thread pitch. Haven't test fitted anything but I measured and took pictures.
Also I found some info in the parts catalog which may be good to someone, the bolts part numbers as well as bearings.
Does it mean that the 340 M45R diff has two different bolts?
As for the shorter bolt that looks like in FREJ's pictures... part no 3285756, I cannot find any info on it's pitch thread.
I will update when I've measured bolts as well.
Thread pitch 1.5
perkabrod
Re: 360 LSD.
Post by perkabrod »
Is it possible to locate M12x1.5 bolts or are we doomed? Unless something's oval I guess it's possible to make everything fit. But I cannot find a single place that sell bolts that looks suitable.
miniswift
Re: 360 LSD.
Post by miniswift »
Can you tell me what length you need?
Do you need cap head or hex head?
They can be bought in internet like ebay very easy in UK.
http://www.ebay.co.uk/itm/M12-x-1-5P-Fi ... 43b21cf597
Atchi
perkabrod
Re: 360 LSD.
Post by perkabrod »
30 mm length would be ok, measured today, but it should be partially threaded and I forgot to measure the distance where there should be no threads. I believe the ones on eBay isn't partially threaded if ordered M12 1.5 12.9 grade in only 30 mm length.
miniswift
Re: 360 LSD.
Post by miniswift »
I think what you need to do is to measure non threaded length and over all length.
This way, you can cut them from the correct length non thread bolts. As long as you cut and dress them after, no issue there.
Atchi
FREJ
Re: 360 LSD.
Post by FREJ »
Hello.
I think we should look for a bolt with a head like this.
A bolt with cap head will be to high, especially if a 12.9 washer is used as well.
So hex head "with built-in washer" bolt. M12x1.5 with the right non threaded length.
BMW Hex Head Bolt M12x1.5x24mm High Grade 12.9 1213571
BMW Hex Head Bolt M12x1.5x24mm High Grade 12.9 1213571.jpg (17.87 KiB) Viewed 54538 times
Volvo 360GL 1987, B230 with high comp. 531+V-cam
MS1 V2 + 337cc injectors, fuelpressure 3,5kg. Running Ethanol since 2004
Timo Extractor Manifold 4-2-1
http://www.300power.com
perkabrod
Re: 360 LSD.
Post by perkabrod »
Yes that type of bolt would be great. It was a lot more difficult than I thought to google specific bolts... maybe the best thing to do is like you seem to have been doing, namely, finding a bolt that's used in a car that uses M12, 1.5 pitch quality 12.9 and just hope they are longer than 30 mm.
Gonna be looking.
Also FREJ, I dropped the distancer into the crown wheel but some force was needed to push it so I didn't want it to get stuck. Just wondering in case yours fitted loosely enough to have it fall out if you held the crown wheel upside down?
The distancers' thickness looks good in your photos... Hope to be able to solve this so that I can run torsen diff this summer :360:
Re: 360 LSD.
No association with these other than they were the first google for "M12x1.5 flange bolt" but they show 8.8 and 12.9 in 30 mm length as well as every 5 mm from there
http://www.acornfasteners.co.za/Catalog ... olts&ID=19
If thats any help?
perkabrod
Re: 360 LSD.
Post by perkabrod »
Yes, but in the best of worlds it should be a partially threaded ribbed (serrated, same thing?) flange bolt, 12.9 :cry:
Seems like people go crazy about securing these bolts when I googled other car builds.
Also, I read upon thread pitch and it said 1.25 were less likely to shake loose. So I will try to find perfect bolts and use STRONG thread lock :D
thododd
Re: 360 LSD.
Post by thododd »
Just to help with terminology. The unthreaded section of a bolt would be the 'shank'.
so youre after a M12x1.5 30mm flange head high tensile (12.9 grade) bolt with a shank length of .....
getting closer to being able to give an engineering workshop something work with.
perkabrod
Re: 360 LSD.
Post by perkabrod »
Even deeper into engineering language:
DIN 6921 (1.25, 1.5 and 1.75 thread pitch)
ISO 15072 (fine thread pitch 1.25 and 1.5)
NF E 25-504-1 (fine thread pitch 1.25 and 1.5)
Wonder if 10.9 quality is good enough?
