Anjo's 340Turbo: EFI conversion
Re: Anjo's Project Car: 1986 340GT Special, B14Turbo
Post by volvodspec »
2 more gauges coming up :lol:
above is:
EGT, boost, fuel pressure, volts, oil pressure, oil temperature and water tamperature
coming from the US; AFR
and still searching for a proper unit; digital tachometer with shiftlight (52mm unit)
Dude, when are you gonna have time to glance at the road?
Its going to be like piloting the Starship Enterprise.
You need a co-driver/engineer to run with you full time. :lol:
vØlvØfreak
Post by vØlvØfreak »
volvodspec wrote: and i also made a deal that's gonna make lots of people here drewell !!! more info on that goodness later, when the stuff is in my posession.
Cool! :D
volvosneverdie wrote:Dude, when are you gonna have time to glance at the road?
:lol: I love your type of humor dude sm4
another package has arrived!
Advanced Engine Management wideband lambda kit, a really horny gauge that displays digital and analogue-style at the same time: http://www.youtube.com/watch?v=aMRhIMBJmgk
The dash will be looking like this shortly:
:lol: naa that WOULD be a little too much :D i've got some ideas about placing them, i'm sure it will work out just fine and look the tits.
today i placed the new downpipe support bracket:
now the weight of the exhaust is off the downpipe, much better.
fixed the tear in the stainless piece thursday evening; and today i also replaced a bend on the downpipe so the stainless fits perfectly
then i finally got round tying the fuel pump to the car :lol:
something i intended to do a loooong time ago :oops:
hahaha, another too-short vid.
http://www.youtube.com/watch?v=OUvSGpOF_EQ
when the snow is off the road i'll do something about that :lol:
vØlvØfreak
7 march on the ALV? :lol:
Cutler
Post by Cutler »
Imagine try to get that through a TÜV :lol:
jep...thats what i thought.
Sideways @ flat 2 the mat forever!
Rally-gious!
jep, at Terberg i sometimes have heavy terminal tractors for german custumors with TUV approval on the speclist; sometimes a TUV guy comes over and every single dimension etc gets measured and checked with our building specifications; one of them failed actually because i placed the exhaust tip on that tractor slightly too low, 5 second fix but still it's a tough protocol!
glad we don't have that in holland :lol:
but TUV approved or not, i can see enough again with the streamer 5cm up :D
Cutler
Post by Cutler »
this is actually a true story and i won't tell you more than this:
I know some guys who registered a company in a special eastern country so that they can run cars in germany as company cars of that special dummy company and therefore can run cars in germany without TÜV at all.
And the Tax goes to the eastern country...as you can imagine, its not as much as it would be in Germany.
But they still somehow use German ensurance etc.
Pretty nice loophole in the law they found there.
Now of course these cars are not dangerous junkers but well prepared high performance sportscars.
However, i like the story and how they outmanoeuvred the shitty TÜV.
Rally-gious!
hellyeah!!
it was a complete kit this fella had, but unfortunatly the sideskirts were inside a car on his compound, and that car had a forced rear lock and all content including the sideskirts was stolen :( but; i know a guy who has a set of them lying around so i'll use them as a copy, damage on this front and rear spoiler will be fixed, and chances are extremely high that i'm going to modifie this bodykit while i'm at it making it a bit more to my taste.
then there's some bad news, dumpvalve gave up on me;
piston is grooved, and sideeffect of this is that the piston seal twisted and blocked the piston into the housing, it didn't move and was stuck wide open, i heard a really loud SSSSSSSSSHHHHHHHHHHHHHHHHH on the motorway :lol:
but that's unfortunatly not all the bad news :(
the f*cking manifold desided to crack again, same places as last time. i'm verryyyyy temped to throw in a stock b14 at this moment and put the B14T on a engine stand to create a new exhaust manifold from scratch.
ok; quick update:
i'm busy with the new valve cover
burned out the old crankcase breather since this pipe is soldered:
and the new breather pipe; 300% bigger than the original one.
still need to fabricate a plug for the original hole and TIG weld it
and today some goodies arrived:
more goodies; stainless steel manifold!!
hopefully i'll get the engine out at the beginning of next week and start with grinding this manifold into bits and remake it the way it will fit in my engine bay
Pretty, look forward to seeing it in there :D
