Duchess The Volvo 340 CVT
JFB
Re: Duchess The Volvo 340 CVT
Post by JFB »
340pw
benji1985
Post by benji1985 »
good day all, been a busy few days recently but had some time today to do a bit more body work on the car
16/01/17
worked on the windscreen and the wheel arches, and i am pleased to say that the shell is almost ready for paint now
Image20170116_155827 by Benjamin Charlton, on Flickr
Image20170116_155836 by Benjamin Charlton, on Flickr
Image20170116_161321 by Benjamin Charlton, on Flickr
Image20170116_161911 by Benjamin Charlton, on Flickr
Image20170116_162339 by Benjamin Charlton, on Flickr
Image20170116_162349 by Benjamin Charlton, on Flickr
Image20170116_162351 by Benjamin Charlton, on Flickr
Image20170116_162358 by Benjamin Charlton, on Flickr
Image20170116_162409 by Benjamin Charlton, on Flickr
Image20170116_162416 by Benjamin Charlton, on Flickr
Image20170116_162424 by Benjamin Charlton, on Flickr
So now i hope to be able to move on to the panels soon, had a quote to have her painted
more to follow soon i hope
Ben
benji1985
Post by benji1985 »
Good evening all, here is the next update
18/01/17
started by cleaning the inside if the new drivers wing, passenger one had already been done earlier, as i was wire brushing it much to my surprise rust holes appeared..... :shock:
Image20170118_105847 by Benjamin Charlton, on Flickr
there was no sign of rust here the paint was unmarked but then holes....
so i had a little think and was going to weld in a new piece of metal when i remembered the wing that was on her was ok in this area.
Image20170118_105900 by Benjamin Charlton, on Flickr
Image20170118_105912 by Benjamin Charlton, on Flickr
Image20170118_115534 by Benjamin Charlton, on Flickr
Image20170118_115545 by Benjamin Charlton, on Flickr
Image20170118_151210 by Benjamin Charlton, on Flickr
I then painted the inside of both wings with rust encapsulator
Image20170118_151217 by Benjamin Charlton, on Flickr
Image20170118_151221 by Benjamin Charlton, on Flickr
while they were drying i put the old suspension together so she will become a rolling shell to go and get painted
Image20170118_151232 by Benjamin Charlton, on Flickr
Image20170118_151235 by Benjamin Charlton, on Flickr
Image20170118_152529 by Benjamin Charlton, on Flickr
put a 2nd coat on the inside of the wings
Image20170118_155726 by Benjamin Charlton, on Flickr
i also re coated the bellhousing as i managed to get black splatters on it
Image20170118_155749 by Benjamin Charlton, on Flickr
Image20170118_155742 by Benjamin Charlton, on Flickr
also put on the cheap set of ball joints to allow for a rolling shell
Image20170118_160331 by Benjamin Charlton, on Flickr
more to follow tomorrow :)
Ben
Post by MCHUDD »
Cracker job your doing.
sm4 sm4 sm4 sm4 sm4
benji1985
Post by benji1985 »
A few more updates
19/01/17
started to work on the doors today, sanded back and found the little dents and wire brushed all the drain hole and the bottom edge
Image20170119_115137 by Benjamin Charlton, on Flickr
Image20170119_123831 by Benjamin Charlton, on Flickr
Image20170119_132515 by Benjamin Charlton, on Flickr
Image20170119_132524 by Benjamin Charlton, on Flickr
Image20170119_132527 by Benjamin Charlton, on Flickr
found a small rust hole in the bottom of the rear door and two holes that had been made by screws :shock:
welded it up and carried on with the dents which turned out to be a shallow but big dent
Image20170119_144452 by Benjamin Charlton, on Flickr
Image20170119_144456 by Benjamin Charlton, on Flickr
Image20170119_145554 by Benjamin Charlton, on Flickr
Image[/url]20170119_154451 by Benjamin Charlton, on Flickr
started on the other front door
Image20170119_154500 by Benjamin Charlton, on Flickr
Image20170119_154503 by Benjamin Charlton, on Flickr
Image20170119_160514 by Benjamin Charlton, on Flickr
rear door sanded but needs a 2nd coat
Image20170119_163934 by Benjamin Charlton, on Flickr
painted up the front doors
Image20170119_164921 by Benjamin Charlton, on Flickr
Image20170119_164933 by Benjamin Charlton, on Flickr
Image20170119_164937 by Benjamin Charlton, on Flickr
noticed a couple of little dents i missed
other door painted
Image20170119_164948 by Benjamin Charlton, on Flickr
Image20170119_164955 by Benjamin Charlton, on Flickr
Image20170119_165015 by Benjamin Charlton, on Flickr
so a bit more filler needed tomorrow
more to follow
Ben
benji1985
Post by benji1985 »
next installment
20/01/17
started on the front door, sorted out the little dents that were found after painting the day before
Image20170120_092759 by Benjamin Charlton, on Flickr
Image20170120_092803 by Benjamin Charlton, on Flickr
and finished the filler on the rear door
Image20170120_092809 by Benjamin Charlton, on Flickr
rust encapsulated the bottoms of the doors
Image20170120_092824 by Benjamin Charlton, on Flickr
finished off the front door
Image20170120_122748 by Benjamin Charlton, on Flickr
finished the rear door (still need to do the other when it arrives)
Image20170120_122755 by Benjamin Charlton, on Flickr
while the filler was drying i put the old front suspension together
Image20170120_122824 by Benjamin Charlton, on Flickr
Image20170120_124416 by Benjamin Charlton, on Flickr
Image20170120_124422 by Benjamin Charlton, on Flickr
Image20170120_143130 by Benjamin Charlton, on Flickr
Image20170120_143141 by Benjamin Charlton, on Flickr
doors painted again
Image20170120_132930 by Benjamin Charlton, on Flickr
Image20170120_132939 by Benjamin Charlton, on Flickr
Image20170120_132949 by Benjamin Charlton, on Flickr
then i decided to work on the wings as they need filler, so decided to bolt them on and work on the car......
BUT THERE IS A PROBLEM..... :shock:
Image20170120_151422 by Benjamin Charlton, on Flickr
Image20170120_151436 by Benjamin Charlton, on Flickr
Image20170120_151444 by Benjamin Charlton, on Flickr
as you can see the lower windscreen is not right
and you can see it is siting a bit forward
Image20170120_151515 by Benjamin Charlton, on Flickr
and the doors gap is quite close
Image20170120_151549 by Benjamin Charlton, on Flickr
i think ill hang the front doors that will go on her to be painted and test the gaps, any suggestions would be very helpful please :)
look at the nice bits installed
Image20170120_154711 by Benjamin Charlton, on Flickr
passenger front wind looking good
Image20170120_155522 by Benjamin Charlton, on Flickr
drivers wont bolt up underneath
Image20170120_155538 by Benjamin Charlton, on Flickr
bonnet lines up ok (not bolted in at all)
Image20170120_155604 by Benjamin Charlton, on Flickr
front wing getting treatment
Image20170120_155613 by Benjamin Charlton, on Flickr
wings 50% there
Image20170120_163314 by Benjamin Charlton, on Flickr
Image20170120_163327 by Benjamin Charlton, on Flickr
some more looks at my cock up area!!!
Image20170120_163352 by Benjamin Charlton, on Flickr
Image20170120_163438 by Benjamin Charlton, on Flickr
Image20170120_163446 by Benjamin Charlton, on Flickr
Image20170120_163451 by Benjamin Charlton, on Flickr
Image2017-01-20 16.51.24 by Benjamin Charlton, on Flickr
doors need seam sealer on along the bottom and then maybe a paint over then they are ready for painting
Image20170120_163709 by Benjamin Charlton, on Flickr
Image20170120_163757 by Benjamin Charlton, on Flickr
Image20170120_163922 by Benjamin Charlton, on Flickr
Any advice would be welcomed please, but it looks like i have to cut out and do the gutter again and sort out the the indent...
Anyone in devon good with body work....
Ben
benji1985
Post by benji1985 »
good day to you all,
25/01/17
so after the discovery of my cock up around the wing and windscreen i sepent the day correcting the issue, first i set out cutting the side out again and gentle cutting the weld from under the corner of the windscreen by the wing.
Image20170125_122140 by Benjamin Charlton, on Flickr
then massaged the corner out and test fitted the wing (also ground down any welds on the inside of the wing that might have been causing issue to allow it to fit better)
Image20170125_124140 by Benjamin Charlton, on Flickr
Image20170125_131759 by Benjamin Charlton, on Flickr
I then cut a new piece of metal out an re built the lower gutter
Image20170125_141513 by Benjamin Charlton, on Flickr
rust encapsulated
Image20170125_145936 by Benjamin Charlton, on Flickr
Image20170125_150954 by Benjamin Charlton, on Flickr
Then replaced the top layer with a new piece of metal
Image2017-01-25 15.42.27 by Benjamin Charlton, on Flickr
welds cleaned up and a key'ed for the filler to stick to
Image2017-01-25 16.17.48 by Benjamin Charlton, on Flickr
as you can see with the wing back on it looks spot on now
Image20170125_162444 by Benjamin Charlton, on Flickr
Image20170125_162446 by Benjamin Charlton, on Flickr
and the gap is more reasonable
Image20170125_162455 by Benjamin Charlton, on Flickr
coated with some paint to protect till friday
Image20170125_163508 by Benjamin Charlton, on Flickr
more filler on friday
we are getting there at last!! :340: :D
Ben
benji1985
Post by benji1985 »
good day all, next update on duchess
27/01/17
applied some filler and etch primer the clutch servo bracket
Image20170127_113529 by Benjamin Charlton, on Flickr
Image20170127_113531 by Benjamin Charlton, on Flickr
Image20170127_113536 by Benjamin Charlton, on Flickr
Image20170127_113543 by Benjamin Charlton, on Flickr
Image20170127_113546 by Benjamin Charlton, on Flickr
also removed the proud welds from the inside of the wing that was stopping the wing sitting correctly
sanded back the filler applied some more, and applied seam sealer to the doors
Image20170127_113618 by Benjamin Charlton, on Flickr
Image20170127_113623 by Benjamin Charlton, on Flickr
Image20170127_113626 by Benjamin Charlton, on Flickr
Image20170127_113637 by Benjamin Charlton, on Flickr
Image20170127_113644 by Benjamin Charlton, on Flickr
and then the filler was still not set, so moved on to putting the old steering rack in so she can be rolled away
Image20170127_131213 by Benjamin Charlton, on Flickr
Image20170127_131219 by Benjamin Charlton, on Flickr
Image20170127_131226 by Benjamin Charlton, on Flickr
sanded back the filler and added a little more
Image20170127_131230 by Benjamin Charlton, on Flickr
Image20170127_131237 by Benjamin Charlton, on Flickr
Image20170127_131238 by Benjamin Charlton, on Flickr
attached the bracket back to the bell housing
Image20170127_150050 by Benjamin Charlton, on Flickr
painted the wings over to protect
Image20170127_162024 by Benjamin Charlton, on Flickr
Image20170127_162034 by Benjamin Charlton, on Flickr
Image20170127_162044 by Benjamin Charlton, on Flickr
Image20170127_162051 by Benjamin Charlton, on Flickr
Image20170127_162101 by Benjamin Charlton, on Flickr
and painted the windscreen to protect....3rd time luck
Image20170127_162114 by Benjamin Charlton, on Flickr
Image20170127_162118 by Benjamin Charlton, on Flickr
refitted the wing loosely to check again the gap and looks pretty good, much much better than before
Image20170127_162219 by Benjamin Charlton, on Flickr
Image20170127_162311 by Benjamin Charlton, on Flickr
Image20170127_162319 by Benjamin Charlton, on Flickr
Image20170127_164431 by Benjamin Charlton, on Flickr
Image20170127_164438 by Benjamin Charlton, on Flickr
Image20170127_164453 by Benjamin Charlton, on Flickr
i feel the windscreen needs a bit more work it does not yet have the sight arch in the downward section the other side has, but that is contouring
hope that it wont be long till she is ready to go and be painted
Ben
JFB
Post by JFB »
sm18 340pw
benji1985
Post by benji1985 »
Hello all, a small update today.
02/02/17
As the weather is so bad, I decided to have a look at painting the chrome parts to make them look erm more chromed...
Couple of test pieces, to trial it out.
Started by sanding and cleaning the parts
Image20170202_102105 by Benjamin Charlton, on Flickr
Image20170202_103046 by Benjamin Charlton, on Flickr
Image20170202_140246 by Benjamin Charlton, on Flickr
Image20170202_140303 by Benjamin Charlton, on Flickr
Image20170202_140307 by Benjamin Charlton, on Flickr
Image20170202_170638 by Benjamin Charlton, on Flickr
I think it needs a coat of lacquer over to protect and make it shinny.
What do you guys think?
Ben
JFB
Post by JFB »
I algo need to do that to my car
benji1985
Post by benji1985 »
Hello all, after trying the chorme idea i was not happy with it, so going back to the drawing board on that idea.
another update for you all
05/02/17
I was allowed a few hours on the car, so I used them to finish of the windscreen.
Image20170205_110902 by Benjamin Charlton, on Flickr
lots of sanding later and also had a section near the wiper arm hole to sort
Image20170205_124916 by Benjamin Charlton, on Flickr
Image20170205_124920 by Benjamin Charlton, on Flickr
Image20170205_124924 by Benjamin Charlton, on Flickr
Image20170205_124928 by Benjamin Charlton, on Flickr
Still got this little lump on the other side to sort, hammer or grinder...
Image20170205_125749 by Benjamin Charlton, on Flickr
but overall she is looking good
Image20170205_125800 by Benjamin Charlton, on Flickr
Ben
Lots of work again :D
Personally I'd fit black window trims off a GLT/later 340 as the chrome always fades and it may be hard to replicate the original effect without it looking too silver.
benji1985
Post by benji1985 »
SteveP wrote:Lots of work again :D
That is a valid point and i do have chrome and black window trims
hummmm :roll:
Ben
benji1985
Post by benji1985 »
Had a goodie turn up today.
09/02/17
I have managed to get hold of a snowcap :D
Image20170209_221409 by Benjamin Charlton, on Flickr
Please feel free to be jealous
:lol:
Ben
