Nikdev and his 360 Gl....
Nikdev
Post by Nikdev »
Do i dare link the rear? It works nice now, apart from height and adjustability. Was thinking of running with leaf spring but if its recommended i will reinforce those towers
Was at the last "powerdrift" training this season yesterday. I got more committed and it was the first time i was feeling the car hold me a bit down.
So now i got the idea of what i need to sort out to next season.
First of all front suspension is useless in high speeds, and as I got the speed up yesterday I was hitting the limiter in third when i initiated drift. The new setup should sort that out.
I will take the full list of things who needs modifying one day. But I have decided to stick with the Volvo, I just loove it!
Jason B
Post by Jason B »
well, adam spoke to a friendly car body guy who told him that the towers were actually thick enough skinned to be used to take much greater forces without tearing. However I think I'd be tempted to reinforce the points if I was going to use the car solely for motorsport as it puts much greater stresses and strains on the car.
garth
Post by garth »
Yeah if you cant turret them, just put another thick skin on top to reinforce them. Keep your pics coming!
Jason B wrote:However I think I'd be tempted to reinforce the points if I was going to use the car solely for motorsport as it puts much greater stresses and strains on the car.
Ain't that the truth... even with the small amount I do in Fake a lot of it is showing wear in places you'd not normally expect.
Post by filthyjohn »
If they're almost strong enough now, you could just weld a big brace across the two, and tie it in to the floor a bit too. The biggest problem is that the damper mounts are a common rot point.
Jason B
Post by Jason B »
yeah, as a minimum then I'd strengthen the current points but if I was spending real money on fancy coilovers then I would seriously consider turreting and using a properly linked dedion setup like some caterhams/overengineered alfas
Nikdev
Post by Nikdev »
I will look into the turrets when i hopefully get my cage next week.
But today i finally got home my top mounts from Dai, don't know it i need them now as I am getting coil overs, but its nice to have
Nikdev
Post by Nikdev »
One more pic for you of them:
Also moved the battery to spare wheel well and hoked up the cut off switch:
Battery:
Not finished yet, going to weld the case to the floor, make a metal strap that holds the lid of the box down and paint it
xtrmjks
Post by xtrmjks »
Nice work !! What happening with coilovers??
Nikdev
Post by Nikdev »
xtrmjks wrote:Nice work !! What happening with coilovers??
They are coming soon :D
BTW, another pic from last training, It can go wrong sometimes :lol:
And more flying bonnet:
Frits
Post by Frits »
I'm not for sure, but the coilovers I have seen had original topmounts. So you could probably still use them.
Grtz
Doherty_nova
Post by Doherty_nova »
love it!!
stunning work youv done there man 8)
alley cats are the nuts ( very very good )
what j and ET are those ones??
im lookin for simular protrusion ( if thats a word lol :lol: ) of the rim from my arch... i was thinkin about 7.5j 13"rims with 175 50 13 tyres...im just unsure what ET they'd need to be so they protrude like in that pic posted above...
that pic is amazing btw...shows the cars real mean looking stance!! also how did you go about acheiving the chamber for the pic in your avatar?? are those the top mounts Dai supplies?? and the rear??
hope that makes sense and that you can help :D
thanks and keep the updates coming 8) :wink:
Nikdev
Post by Nikdev »
Thancks mate, It is stock 360 camber 8)
The Allycats rims are 13x8, et-7
The rims in my avatar is 13x8 et4
Currently all my suspension apart from front dampers and sway bar are from Dai
Doherty_nova
thanks for the info help man :wink:
keep up the updates!! truly a stunning volvine that gets used good and proper :twisted: :lol:
Nikdev
Post by Nikdev »
Little update.. The car has gone indoors, And it is completely stripped out again, this time its getting a cage
The cage is from Pedersen Racing in Norway, its a self build cage. So all the bends are made, but you need to cut and build it yourself.
I had the options of weld or bolt it to the car, I went for the weld option because it will strengthen the car
Its not a dash dodging cage, so to get it right I had to get the dash out
Surprisingly simple job thanks to Haynes :wink:
Left is a lot of wires i don't need, and some more kg`s of sound deadening
You can see the front floor plates on the dash photos.
Here's a pic of one of the boxes we made for the center of the cage.
I will try to take photos as the construction goes on
