Re: Turbo 360 - underside resto
Posted: 22 Sep 2011 08:23 pm
I have neither and almost buy cars every week
http://volvo300mania.com/uk/forum/
Speedy88 wrote:I have neither and almost buy cars every week
So do I, but then I sell them at a loss.Matthew Corbett and Sooty wrote:THATS THE WAY TO DO IT!
Just spotted this...might be useful for future reference. All B200/230s mated to an M4x (M45, M46, M47) gearbox use the same spigot bearing as a 360...the part number is the same. It's one of relatively few 300 series parts you can still get...because it's not really a 300 series part!pyro wrote:1) the spigot bearing didnt need to be changed on my engine when i did the swap, was the same size as the 360 one, still not hard though, ITs the clutch shaft/input shaft support bearing, nothing fancy, easy swap, and the one from the 360 engine is as direct replacement. the 940 vs 360 spigot bearing must have a different internal diameter hence the swap, straight swap though.
Hell no! We have discussed this before, and I find them crap.Ride_on wrote: use hole cutter spot weld cutters with 3mm drill for pilot hole.
