Performance parts cat
bebbinator
Re: Performance parts cat
Post by bebbinator »
classicswede wrote:
bebbinator wrote:hi do you do a performance 1400 manifold also how much will it be
Are you looking for an inlet or exhaust manifold
hi im looking for an exhaust monifold (not turbo)
magnumpi
Post by magnumpi »
^ Give him a ring or txt mate, he's a busy boy ^
His number is in the 1st post at the top :D
bebbinator
hi i cant get hold of him ??
Sorry not checked this thread for a while.
1.4 exhaust manifold would be £250
Regards
bebbinator
no worries PM`D
bebbinator
how much for
rear shocker bushes
leaf spring bushes
1" lowering blockes
wishbone bushes
engine mounts
tie rod bushes
antiroll bar bushes
antiroll bar links
paulvolvo
Post by paulvolvo »
Want a set of anti roll bar pin kits and maybe some poly engine mounts....
do you do rear shocker bushes, have sent you a email to you email address you use on you messages on here.... :)
bebbinator wrote:how much for
rear shocker bushes £15
leaf spring bushes £38
1" lowering blockes £25
wishbone bushes £30
engine mounts £36 pair
tie rod bushes £25
antiroll bar bushes £12
antiroll bar links £25
paulvolvo wrote:Want a set of anti roll bar pin kits and maybe some poly engine mounts....
Email replied. Dampers bushes £15 set
krazvy
Post by krazvy »
hello ... do you still have a pair of Front Classic Swede top adjustables and a Rear alu lowering blocks with bolts a set 3" lowering
theo2468
Post by theo2468 »
would like to purchase some 1 1/2 inch lowering blocks please dai
cheers theo
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
krazvy wrote:hello ... do you still have a pair of Front Classic Swede top adjustables and a Rear alu lowering blocks with bolts a set 3" lowering
Still have a few sets left of the top adjustables. Also have the 3" lowering block kits in stock.
theo2468 wrote:would like to purchase some 1 1/2 inch lowering blocks please dai
cheers theo
Hi Theo,
will PM you details tomorrow.
theo2468
Post by theo2468 »
vØlvØfreak
Post by vØlvØfreak »
Hi Dai,
I did send you a PM about poly bushes rear leaf spring kit.
Mark
