econometer fixing..
- foggyjames
UPDATE! Econometer fixing the non-Ug way!
Remove needle and face, then submerge in white spirit overnight. In the morning, the white spirit looks like bog water, and you have a working econometer! Or more to the point, Mick does...
- petefarrell360
fitted my econometer
, much easier than I thought , just got to get a t piece for the other end of the hose and work out which hose to cut.
HOWEVER
I did make the very basic but often overlooked mistake of swapping the electrical plugs on the back of the dash over
, this was spotted when I switched the ignition on and saw smoke coming from the back of the dash
, I will have to replace the dash as part of the blue circuit board melted and now when I put the lights on the ambient temp gauge drops to -40 and the right hand indicator , high beam and heated rear window warning lights come on
HOWEVER
- huskyracer
- huskyracer
- petefarrell360
DOH!
Unlucky mate, if only I wasn't up in London all week, or you could call over and get the new cluster. Evenings are difficult for you, but we'll sort it out! Simple mistake, but it can be a costly one. I've always worried about swapping them on refitting, so make sure they're not going to move and cross over, or a bit of masking tape with a marking on it to correspond with the other connection, a bit OTT, but better safe than sorry.
Smoke, dash board... dejavu dejavu dejavu..............
