my volvo 360
Re: my volvo 360
This'll be great with the 230 in
Re: my volvo 360
i hope so
engine is ready to go in waiting on a clutch
Re: my volvo 360
small update
still waiting for a clutch
but got a rover turbo throttle body converted to fit a volvo injection inlet manifold so fitted that and blanked off the injector holes
2.5 inch all the way through
and it mocked up with the lpg carb
and a random group a air filter i had luying about
then got onto the engine
started off with this
new end cover seal
crank and intermidiet cam seal
new water pump annd seals
swaped over sumps and pick up pipes
new timing belt+ tensioner
re fitted everything
quick pain on the block
and the rocker cover red ( with green volvo lettering .......
and here it is
u might see that the car has alot of lock.... ive made washers to space the bump stops in the rack all i need to do now is get the alignment set up a bit better and test it out
i also wire up my wide band lambda and started running llpg pipes but ill explain that more later on once i finished it
thats all for now
new end cover seal
and here it is
thats all for now
Re: my volvo 360
got it running last night on petrol (after removing the engine again due to fitting the flywheel 90* out
tomorrows job tidy it up abit and then swap inlets to my gas one
happy new year!
happy new year!
Re: my volvo 360
Awesome! What injection system are you running? From the donor or carbed? Happy new year
Re: my volvo 360
carbed it was a b19a i think on a cd175 carb so im just removing the carb fitting a throttle body and a lpg carb and keep standard ignition
Re: my volvo 360
its running on gas verry happly
will get better pics on the weekend
Re: my volvo 360
Make sure you do not have any rev limiter or you will get a big bang if you hit it!crazydan wrote:carbed it was a b19a i think on a cd175 carb so im just removing the carb fitting a throttle body and a lpg carb and keep standard ignition
Re: my volvo 360
i wasnt sure if i should fit one or notclassicswede wrote:Make sure you do not have any rev limiter or you will get a big bang if you hit it!crazydan wrote:carbed it was a b19a i think on a cd175 carb so im just removing the carb fitting a throttle body and a lpg carb and keep standard ignition![]()
is this you talking from experience or?
Re: my volvo 360
Over the year I've had a lot of folk come to me with smashed up air intakes, blown up manifolds, damaged mixers and vapourisers due to backfires from rev limitrs amoungst other things.
Re: my volvo 360
yeah quite the common thing with gas
ive got a non return valve (1.5") fitted so with a vacuum its shut but if it does flash back it just puts it out the valve did it once on me today whilst setting it up (my own fault turned the adjuster the rong way
)but seemed to do the job spot on!
Re: my volvo 360
You mean a pop off valve?
Re: my volvo 360
yeah think thats the proper name for them
Re: my volvo 360
ok update
car has been running for the past week spot on (except the gas vaporiser going so now back on petrol)
think the cars going to get used for autotest etc now so my mate ( who i sold the bike carbs to) is going in halfers for the car with me
so bike carbs are getting fitted again
also fitted my 3" dished wheel love it
Re: my volvo 360
Pics or it didn't happen
