Custome's "MM Styling" 360
Re: Custome's "MM Styling" 360
I love the whole car. The colour of the interior is awesome!
Thanks for sharing dude.
Customer
Post by Customer »
Thanks.
I loved to beige interiors and metal paint. 360 have also them.
Today i washed 360 over all. Now it are in garage waiting next project steps! :wink: :360:
wolfpack
Post by wolfpack »
would you be interested in making a body kit to sell ? i have wanted to get some side skirts for a long time
Customer
Post by Customer »
I not have sideskirt moulds. I have moulds for front and rear spoilers. Yes maybe making is possible when i get time for it. The problem is; i don't know anything how to shipping to other countries.
I started building again. First i drop the driveline to floor. Orginal factory asembled clutch needs change. It are drived 270tkm, distance to rivets are 0.3-0.5mm... Shiftlinkage needs repair, left driveshaft is worn. some
seals needs replace. Finaly i build new exhaust system. Removed parts gets new paint before installation. Maybe i remove also rearaxle, it needs sandplasting and new paint. Also i replace brakehoses.
Customer
Post by Customer »
Little cleaning project sm4
All seals is new in differential cover. Hopely oil stays inside now.
Nimminz
Post by Nimminz »
that looks so good!
What did you use to clean it so well? I just painted my gearbox (bright yellow). I'm having to swap gearboxes again so would love mine to look so clean!
Customer
Post by Customer »
First i washed with pressure washer. Second wash by hand with brake cleaner. Most oxidations removed by steelwire brush and kinfe. Then paint.
That looks very cool. There's something awesome about clean parts.
Customer
Post by Customer »
Little chassis fixing:
Body is rust protected, chassis parts is sandblasted and painted thick.
Good condition under there, difference is I had to depanel everything to get to that level.
I have done something similar with the painting, still to do the gearbox and one of the brackets though. Unfortunately only discovered sandblasting after I did the axle, so it may rust through sometime. Will see how it lasts but wil probably keep garaged if possible.
Resin is the best for sealing, but hard to work with seems to take weeks to harden properly in my case, I covered too early with chassis black and then took months to harden, but I've still not used the front suspension parts yet. All my parts are heavily pitted so I may try and collect some nicer items if they are available.
Did you paint the aluminium hubs and change the rear bearings?
My 360 Saloon
My 360 Saloon
Looks really good man, love the rear Louvre too.
Customer
Post by Customer »
Thanks!
Yes wheelbearing hubs is painted and ready to assembly new bearings. Bearings come from italy maded by breda lorett. How 300 brothers, are that bearings good?
I also change new bracke cylinders and brakehose to rear axle. Brakebads are 2 years ago changed. Front brakes also gets new hoses now.
Also i must do new fueltank collars from stainless steel.
Looking very good. Nice to see someone going to such detail in a rebuild.
Customer
Post by Customer »
I build new gastank collars from stainless steel.
Customer
Post by Customer »
Some assembling done.
Rear axle assemled.
Restored gaspump holder.
