lowring my volvo
Attack2001
Re: lowring my volvo
Post by Attack2001 »
Its all been set-up on a 4 wheel aligner like so:
Apart from that, the tyres are crap, the stretch is too much, the fronts too stiff... so i've got to get it all sorted out :)
Thanks, Thomas................
Evoman
Post by Evoman »
I thought you wanted a stiffer front for a rwd?
Attack2001
You do indeed :) However running 400lbs on the front and im guessing its less than 150lbs on the back, it doesnt work :lol:
400 at the front and less than 100lbs at the back!
Attack2001 wrote:Its all been set-up on a 4 wheel aligner like so:
I did not know what the settings should be but a quick google came up with this post from mac
Camber front:-
340 B14 = +30' (+30")
340 B172 = -30' (+/- 30")
340 D16 = -30' (+/- 30")
360 All = -30' (+/-30")
Camber rear:-
300 All = -2 deg. (+/- 30')
KPI:- 300 All = 9deg.35' (+/-35')
Castor:- 300 All = 7deg.30' (+/-30')
Toe-in:- 300 All Measured on wheel rim = 3.1mm (+/-0.8mm)
Measured at outer edges of tyre = 5mm (+/-1mm)
Measured at centre of sidewall = 4mm (+/-1mm)
Mollusk
Attack2001
Mines not been set-up to standard alignment, i chose the angles to run it at :) We only stopped a .9 of a degree as it was taking too much time and i just said that'l do, its close enough :) Whos going to be first to go IRS then?
Thomas.................
