Page 3 of 4
Re: Nolan's 340 pick up D-project F7p (need help for Vss)
Posted: 11 Jun 2015 05:44 pm
by Nolan
I've taken the + from the horn and the same for the ground. In the middle (A), i've connected the wire from the module and another wire from Eprom (A6 primary speed sensor wire)
I've removed all the resistors from the old cluster!! :oops: sm2
Posted: 11 Jun 2015 05:57 pm
by Nolan
The problem is:
Don't know where was each one! :oops:
Posted: 11 Jun 2015 08:34 pm
by Joris
These three you need! (found a old picture :) Not sure which side should be first, but you could find that out by following the +.
The - (negative is really close, the white wire in the picture) Don't mind the other wires..
Posted: 11 Jun 2015 10:51 pm
by Nolan
You have taken the resistors from an old speedo? Or just picked up from your actually speedo?
I don t think having a green resistor from the old dash?
thx
Posted: 12 Jun 2015 03:57 pm
by Joris
Nolan wrote:You have taken the resistors from an old speedo? Or just picked up from your actually speedo?
thx
They should be on the 440/480 dash
Posted: 13 Jun 2015 06:03 pm
by Nolan
You mean i have to cut around the old dash resistors and connect it to the + ?
I've found a pic from my dash:
It's from a 440
Do you think i can put a 5v module reducer like this:
http://www.ebay.fr/itm/DC-DC-KIM-055L-9 ... 418c3dd9e9
It should be easier, i find 12v with the 3 resistors, maybe one is on the wrong side now...
Posted: 13 Jun 2015 08:28 pm
by Joris
Nolan wrote:You mean i have to cut around the old dash resistors and connect it to the + ?
It's from a 440
You need the three next to each other on the left. Cut them out and wire them in parallel, take notice of the direction they are installed. You need to do the same direction. Tape them together and put them in the + wire.
Posted: 13 Jun 2015 08:47 pm
by Nolan
Yes, but the problem is that i don't know exactly how the resistors were placed, i don't have the same resistors than yours and can't see exactly with the only picture i have :oops:
http://www.hostingpics.net/viewer.php?i ... esized.jpg
Posted: 13 Jun 2015 09:07 pm
by Nolan
I think it was like that:
Posted: 13 Jun 2015 10:54 pm
by Joris
Looks good!
Posted: 13 Jun 2015 11:13 pm
by Nolan
Yeah, i'm going to try it tomorrow, just have to connect the 3 together like on the picture with a wire on each side, the up on +12v, and down on Vss + if i'm right...
Thanks!
Posted: 14 Jun 2015 07:01 pm
by Nolan
I have tried as you said, but i find 12v too... is it normal? Should it be connected in series?
I'll try with a 12v-5v converter, i'll be sure having 5v output!
Posted: 15 Jun 2015 07:16 pm
by Nolan
brake servo fixed (but i would prefer to fix it straight but it wasn't possible!)
I'll have to try when it will be fixed on the brake pedal...
Posted: 28 Jun 2015 09:30 pm
by Nolan
The engine always idles at about 2/2500rpm... I've put a 12v/5v converter for the vss, but now the rev counter doesn't work... :evil:
Maybe in case of this i need to connect on Ecu (i'll put a Clio sensor):
I'm actually working on servo relocation and exhaust:
Posted: 29 Jun 2015 11:31 am
by kohshin
ca avance bien 340pw
