Lowering anyone????
- 340GLT
Ok can you go for the height i want to suit the 1.4? Then i will use those springs on the spax and as they will increse height the engine will lower it again so jobs a gud un!!!
Cheers Adam
Cheers Adam
- RandomHero
This the autoballans system under his car, it's quite simple and works very wellbodejodel wrote:One of the guys in the 360NoModenaCup has stock shocks, stock coils minus 2 windings, 3 sets of Niveau Plus rings, and the autoballans system.
His ride is almost rock hard and he is the fastest car on the track.
- 360 GLT, 1989, Gray Metallic, 115.500 km, PAS, Electric Sunroof, Windows and Mirrors
- RandomHero
The Spax ajustables can be set to make the rear so stiff you can not compress the springs by pushing on the back of the car. They almost completly eliminated roll on the rear.
Anyone going to the meet should get a chance to find out for themselfs.
Sorry bodejodel too far away for you.
Re: Lowering anyone????
ZOMFG zombie thread, run for your lives........
But while it's up, I'm curious about those autoballans things, but can't seen to find much info on the internets. And what are Niveau Plus rings? I assumed they're donut type spring assistors for the front coils... Interesting.
Ps: WOOOOO.
Ps: WOOOOO.
60mm blocks should be fine, mine is running 75mm ones on the back. and the front i just lopped off 3 coils ( not at once though - just incase)
this was the result
and it still drives ok, but you will know about every dip and bump in the road, and so will your floor pans
EDIT: remind self to check post dates
this was the result
- mrsoundcraft
Those rings are great to stiffen up your front coils when you chop of a couple of windings from a stock coil. I did it on my previous 360. Worked great. I have the autoballans balls, but your rear needs to be lower than stock for them to work. Otherwise they will not make contact.Jonofdoom wrote:ZOMFG zombie thread, run for your lives........
Ps: WOOOOO.
ATM I am running new yellow adjustable Koni shocks front ( with stiff coils) and rear (+ aux coils mounted on the rear axle) and I love it! I have installed all the PU bushes and the Dai sway bar too. It now handles like a true sportscar minus the speed.
